fredsopwith Posted August 14, 2010 Share Posted August 14, 2010 Hi all. Bit of a chesnut this one, but how was the lozenge fabric applied to LVG's? I am just about to start appyling it to my WNW effort so I am keen to get it right. Was the fabric applied so that it aligned with the adjacent strip, so that the patten repeated itself evenly, or was it applied "as it came" making the join lines break the pattern ? Cheers John. Link to comment Share on other sites More sharing options...
Antoine Posted August 14, 2010 Share Posted August 14, 2010 You should check wingnuts web page, your question is answered there. Link to comment Share on other sites More sharing options...
blimp Posted August 15, 2010 Share Posted August 15, 2010 (edited) looking through some old refs i found this , a drawing based on the shuttleworth restoration - the pattern was not 'aligned' ( * it would waste material ) all the best , Blimp . [/left] - p.s. heres a picture of the real thing . note the join at the base of the struts - seams were not permitted on the ribs. Edited August 19, 2010 by blimp Link to comment Share on other sites More sharing options...
fredsopwith Posted August 19, 2010 Author Share Posted August 19, 2010 Thanks for the feedback. Guess it makes sense really. Lengths of fabric wouldn't be wasted, just to get the pattern neat. Link to comment Share on other sites More sharing options...
eclarson Posted August 19, 2010 Share Posted August 19, 2010 Hi all. Bit of a chesnut this one, but how was the lozenge fabric applied to LVG's? I am just about to start appyling it to my WNW effort so I am keen to get it right. Was the fabric applied so that it aligned with the adjacent strip, so that the patten repeated itself evenly, or was it applied "as it came" making the join lines break the pattern ? Cheers John. Hi John, When I built my LVG last year, I researched the lozenge application rather extensively. What I discovered is that there are a couple ways it can be done. One way would have you applying the lozenge strips with the pattern going in the same direction for each piece. The other is to have every other panel alternate direction. The latter would occur as the person covering the wing would roll out one section, flip the roll, and roll it back the other way. I studied a number of photos, including models by builders with FAR more knowledge of WWI aircraft than me and saw both ways. I decided to go with the alternating directions on mine. Whatever you decide, you won't be wrong. Just be sure to measure VERY carefully as there is not a lot of extra decal material. I hope these pics of mine will be of help. Cheers, Eric Link to comment Share on other sites More sharing options...
CPNGROATS Posted August 20, 2010 Share Posted August 20, 2010 Your lozenge application looks great....I've only applied such a decal once on a egg Ni-11 of the Vulgarian airforce....the sourced decal came from a 1/48 Roden DVII... Cheers, ggc Link to comment Share on other sites More sharing options...
Shane Posted August 20, 2010 Share Posted August 20, 2010 Hi all. Bit of a chesnut this one, but how was the lozenge fabric applied to LVG's? I am just about to start appyling it to my WNW effort so I am keen to get it right. Was the fabric applied so that it aligned with the adjacent strip, so that the patten repeated itself evenly, or was it applied "as it came" making the join lines break the pattern ? Cheers John. Other answers before mine are pretty much correct. One extra point. The join between fabric strips is *never* on a rib, and so will not be hidden by a rib tape. This is because the joins between fabric strips are the weakest points and the greatest stress on the fabric is at the ribs - not a good idea for them to coincide. Shane Link to comment Share on other sites More sharing options...
CPNGROATS Posted August 20, 2010 Share Posted August 20, 2010 Really..? That's good to know when I go for the next lozenge application...... thanks for the info. Cheers, ggc Link to comment Share on other sites More sharing options...
fredsopwith Posted August 25, 2010 Author Share Posted August 25, 2010 Hi John,When I built my LVG last year, I researched the lozenge application rather extensively. What I discovered is that there are a couple ways it can be done. One way would have you applying the lozenge strips with the pattern going in the same direction for each piece. The other is to have every other panel alternate direction. The latter would occur as the person covering the wing would roll out one section, flip the roll, and roll it back the other way. I studied a number of photos, including models by builders with FAR more knowledge of WWI aircraft than me and saw both ways. I decided to go with the alternating directions on mine. Whatever you decide, you won't be wrong. Just be sure to measure VERY carefully as there is not a lot of extra decal material. I hope these pics of mine will be of help. Cheers, Eric Link to comment Share on other sites More sharing options...
fredsopwith Posted August 25, 2010 Author Share Posted August 25, 2010 All Many thanks again for the generous feedback Eric. I notice in the excellent completed LVG (I presume ) of yours, that there is renforcing lozenge strip around the edges of the flying surfaces. Is there enough decal supplied in the kit to apply this ? I realise that this may not be a standard procces for applying to all examples. John. Link to comment Share on other sites More sharing options...
Shane Posted August 25, 2010 Share Posted August 25, 2010 AllMany thanks again for the generous feedback Eric. I notice in the excellent completed LVG (I presume ) of yours, that there is renforcing lozenge strip around the edges of the flying surfaces. Is there enough decal supplied in the kit to apply this ? I realise that this may not be a standard procces for applying to all examples. John. I'm not Eric, but I'd like to point out that there are photos showing the LVG C.VI with light coloured edge tapes on both the leading and trailing edges, or just the leading edge, with the trailing edge in loz. Or the reverse! It's rare to see a photo of the same aircraft from both front and rear, so getting a sense of whether this happened in any pattern is next to impossible. The best you can do is match the photos of the aircraft being replicated, and make an educated guess about the remainder. Shane Link to comment Share on other sites More sharing options...
eclarson Posted September 8, 2010 Share Posted September 8, 2010 AllMany thanks again for the generous feedback Eric. I notice in the excellent completed LVG (I presume ) of yours, that there is renforcing lozenge strip around the edges of the flying surfaces. Is there enough decal supplied in the kit to apply this ? I realise that this may not be a standard procces for applying to all examples. John. Hi John, I am so sorry that it has taken me this long to reply. I pop in and out of so many modeling forums that I tend to forget what I've posted where! Thank you for your kind words and to answer your question, no, there really isn't enough decal material with the kit to do the edge tapes. That's why you don't see them on a lot of the builds posted around. Not sure why Wingnut didn't provide enough but I was able to obtain an extra sheet of the upper lozenge decals, which is what the edge tapes are made from. One possible explanation as to why Wingnut didn't bother with them is that applying them is EXTREMELY tedious and requires a lot of careful measuring, trimming, and fiddling. Especially around the rounded wing and tail tips. They may have figured that the average person would not want to be bothered. Just my opinion though. Careful study of LVG photos clearly show the tapes. Cheers, Eric Link to comment Share on other sites More sharing options...
