crobinsonh Posted February 23, 2019 Posted February 23, 2019 Hi, Are there any good plans for the HMS Ark Royal R09 and any good models in 1/700 or 1/350? Thanks for your help
Chris Hewitt Posted February 23, 2019 Posted February 23, 2019 There is a 1/700 resin kit produce by Atlantic Models sold from Starling models,the hull and bridge needs some work,but the Photo etching is first class.l will put some photo,s later today.l replaced all the aircraft because l wanted more and found a couple of deck vehicles left over from other carrier builds. 3
Chris Hewitt Posted February 23, 2019 Posted February 23, 2019 (edited) As promised the photo,s of Ark. My assistant ! Edited February 23, 2019 by Chris Hewitt 14
crobinsonh Posted February 24, 2019 Author Posted February 24, 2019 16 hours ago, Chris Hewitt said: As promised the photo,s of Ark. My assistant ! Wow - very nice. You have done a great job on your finish and in bringing life to flight deck. Thanks for sharing this. 2 1
missile-monkey Posted February 24, 2019 Posted February 24, 2019 21 hours ago, Chris Hewitt said: There is a 1/700 resin kit produce by Atlantic Models sold from Starling models,the hull and bridge needs some work,but the Photo etching is first class.l will put some photo,s later today.l replaced all the aircraft because l wanted more and found a couple of deck vehicles left over from other carrier builds. Can I ask, where did you get the replacement 1/700 scale aircraft from? Regards MM
Chris Hewitt Posted February 24, 2019 Posted February 24, 2019 They are the Trumpeter 1/700 U.S. F-4J Phantom II,item no 03423.not easy to find ,if you do, buy then.The Gannets,Buccaneers and Seakings are Orange Hobby,the Wessex is L'arenal. All can be bought from eBay and other sites.
missile-monkey Posted February 24, 2019 Posted February 24, 2019 54 minutes ago, Chris Hewitt said: They are the Trumpeter 1/700 U.S. F-4J Phantom II,item no 03423.not easy to find ,if you do, buy then.The Gannets,Buccaneers and Seakings are Orange Hobby,the Wessex is L'arenal. All can be bought from eBay and other sites. Thank you for the info. Good build by the by...…. Regards MM 1
Mike McCabe Posted May 1, 2019 Posted May 1, 2019 The kit will be available again in the summer, when Chris built the model the extra aircraft sets weren't available, but are now. Mike 1
Charlie Leaver Posted December 11, 2019 Posted December 11, 2019 Hi ,Mike, Have you any details as of when the Ark Royal resin model is availiable from Starling please.
Mike McCabe Posted December 31, 2019 Posted December 31, 2019 The Ark Royal kit is now back in stock as are the extra aircraft sets, Mike
Charlie Leaver Posted January 3, 2020 Posted January 3, 2020 On 2/23/2019 at 2:14 PM, Chris Hewitt said: There is a 1/700 resin kit produce by Atlantic Models sold from Starling models,the hull and bridge needs some work,but the Photo etching is first class.l will put some photo,s later today.l replaced all the aircraft because l wanted more and found a couple of deck vehicles left over from other carrier builds. Hi, just about to purchase the ark from Starling,please could you advise as to the correct overall RN Grey colour code and manufacturer and would you sugest brush or spray aplication Thank You ,Charlie Leaver.
Graham Boak Posted January 3, 2020 Posted January 3, 2020 Look on Sovereign Hobbies for the correct paints. There is another thread running in which the Ark's camouflage schemes are discussed, in which Jamie of SH describes which paints to go for. 1
Our Ned Posted January 3, 2020 Posted January 3, 2020 (edited) The "other thread running" discusses the colour schemes of the Second World War ARK ROYAL, not the ship represented in the Atlantic Models kit. Edited January 3, 2020 by Our Ned
Graham Boak Posted January 3, 2020 Posted January 3, 2020 Apologies for not reading to the end of the title. I suspect that SH will still offer appropriate paints. 1
Mike McCabe Posted January 6, 2020 Posted January 6, 2020 There are paint recommendations in the instructions for the Sovereign Hobbies Colourcoats brand Charlie. Mike 2
Charlie Leaver Posted February 5, 2020 Posted February 5, 2020 Hi please could anyone advise me as to where i can get deck aircraft tugs for the atlantic HMS Ark Royal 1/700 scale resin model. Thank you.
Ex-FAAWAFU Posted February 5, 2020 Posted February 5, 2020 Not sure there are any available - at least, if there are I haven’t found them (& I’d definitely like to)
Charlie Leaver Posted April 13, 2020 Posted April 13, 2020 On 2/23/2019 at 5:44 PM, Chris Hewitt said: As promised the photo,s of Ark. My assistant ! Hi Chris Great work,i am just starting the ark royal build and found when i was pairing down the hull that is has slight banana bend, did you experience this and if so was it detrimental to the build?
Chris Hewitt Posted April 13, 2020 Posted April 13, 2020 hi No my hull was straight,you need to straighten the hull ,it will become noticeable at the end of the build,you need the submerge the hull in hot water and apply pressure to straighten it out ,this might take a couple of goes.
