Spookytooth Posted August 22, 2013 Share Posted August 22, 2013 I am thinking aboutusing Humbrol Metalcote to spray a F84 with. But I am not sure when it comes to putting the decals on wether I should apply gloss varnish first. Also how should one seal the completed job. I have not got any Klear/Future!! Any suggestions please. From a newbie trying out different finishes. Link to comment Share on other sites More sharing options...
pigsty Posted August 23, 2013 Share Posted August 23, 2013 Polished Metalcote has a decently gloss finish, but a little more couldn't hurt. If you can spray the gloss varnish, you'll avoid any risk of lifting the paint (which Metalcote tends to do if you so much as go near it after you've polished it). Sealing, again, should be straightforward with more varnish (gloss or matt to suit). People who use Klear are very happy to use it to seal decals but, in truth, decal setting solutions plus varnish are equally effective. Link to comment Share on other sites More sharing options...
Nigel Heath Posted August 23, 2013 Share Posted August 23, 2013 By over coating with varnish I think you will lose some of the metallic shine from polished Metalcote but I suppose you'll have to varnish it at some point anyway. Link to comment Share on other sites More sharing options...
Spookytooth Posted August 23, 2013 Author Share Posted August 23, 2013 Cheers good people, your advice has been taken on board. Link to comment Share on other sites More sharing options...
Fin Posted May 2, 2015 Share Posted May 2, 2015 I know this is an old thread, but I have similar questions so rather than start another I`ll use this one. Polished Metalcote has a decently gloss finish, but a little more couldn't hurt. If you can spray the gloss varnish, you'll avoid any risk of lifting the paint (which Metalcote tends to do if you so much as go near it after you've polished it). Sealing, again, should be straightforward with more varnish (gloss or matt to suit). People who use Klear are very happy to use it to seal decals but, in truth, decal setting solutions plus varnish are equally effective. I keep reading such allusions that one shouldn`t touch Humbrol`s Metalcote because you leave fingerprints or because it lifts. But, to what extent is this true? Certain parts of the model would require another layer of paint (tail, nose etc.) for the colour scheme. Also, how do you accentuate the panel lines on the metalcoted model? Regular acrylic wash? Should one use gloss varnish before that? The metalcote looks pretty shiny on its own, but if it`s fragile... Link to comment Share on other sites More sharing options...
