paul178 Posted July 7, 2011 Posted July 7, 2011 As I can't get the MATS decals for my heller C121A I thought about plan B. Modelling the prototype NX25600. seems removing the astrodome and deicing equipment is the major mod. The things I am not clear about are the colours. This is the only pic I can find. http://www.zoggavia.com/c_n_1961.html I am presuming olive drab for upper surfaces and it looks like a kharki tip to the nose? What do you recon to the undersides,also props and spinners look black with yellow tips? I would like to build it with flaps down what do you think aluminium for them? So any help on the above would be great. Thanks Paul
Chuck1945 Posted July 7, 2011 Posted July 7, 2011 You are correct for the colors, BUT the original Constellation had the USAAF designation C-69, the C-121 was a different airframe due to lengthening the fuselage approximately 11 feet C-121 length 116ft C-69 length 95 ft
Iain Ogilvie Posted July 7, 2011 Posted July 7, 2011 (edited) Think you'll find C-121A was same length as the civvie L-749 - 95'2" <wanders off to dig out some photo's of prototype> Iain Edited July 7, 2011 by Iain (32SIG)
Jennings Heilig Posted July 7, 2011 Posted July 7, 2011 Not sure where you got those figures from, but the prototype, all production C-69s, and all civilian Connies up through the L-749 had the exact same fuselage length. The only difference would be those C-121s that were retrofitted with weather radar in the 1950s. The C-69s on the assembly line at the end of the war were completed as L-049s for the airlines. The war-era C-69s were standard USAAF Olive Drab over Neutral Gray. The entire exterior surfaces of the flaps would have been painted, no bare metal showing anywhere. The nose was likely just a raw fibreglass color (off white/tan) for the beam approach system antennas. Note that the Heller kit is an L-749 (mostly), which has completely different engine nacelles from the 049. I believe Ha-Hen Models makes (or made) an 049 conversion set. I know someone did at one point. The props in Heller kit are comically huge. Early Connies had very slim prop blades. J
paul178 Posted July 7, 2011 Author Posted July 7, 2011 You are correct for the colors, BUT the original Constellation had the USAAF designation C-69, the C-121 was a different airframe due to lengthening the fuselage approximately 11 feet C-121 length 116ft C-69 length 95 ft Thanks Chuck a rapid measure of a fusalage half and conversion from metric to imperial measurements gives me 95 feet. So I am still good to go with this. FYO it is the short nosed Connie with the Heller box saying "C-121A Constellation 'Berlin' kit no 80382 So I think C69 it is despite the box description. Thank you for your help with the colours also. Any further help with this mod will be greatfully recieved as I am flying blind with this one! Best Wishes Paul
Chuck1945 Posted July 7, 2011 Posted July 7, 2011 my error, I thought the C-121 was based on the L1049 which had a fuselage length of 116 feet.
paul178 Posted July 7, 2011 Author Posted July 7, 2011 Iain and Jennings thanks for your posts also they crossed with me posting my last reply. Keep them coming though I am really up for this conversion Paul
Iain Ogilvie Posted July 7, 2011 Posted July 7, 2011 (edited) my error, I thought the C-121 was based on the L1049 which had a fuselage length of 116 feet. And you wouldn't be wrong - but the 'A' model had the shorter fuse Keep them coming though I am really up for this conversionPaul Good man Paul - one of histories most beautiful aeroplanes IMHO Have quite a bit of stuff on the Connie (it's a bit of an obsession as I'm building one in 1:32 - see link below) - will see what I can dig out. Iain Edited July 7, 2011 by Iain (32SIG)
paul178 Posted July 7, 2011 Author Posted July 7, 2011 Thank you Iain we both agree on the Connies beauty!
Iain Ogilvie Posted July 7, 2011 Posted July 7, 2011 Have some pix - if you can wait until the weekend I'll happily scan and email over. Can you send me a PM with your email addy? Iain
Iain Ogilvie Posted July 7, 2011 Posted July 7, 2011 Not sure if you realise - but Daco still showing the MATS decals on stock: http://ultra.glo.be/daco/KSky56.html Iain
paul178 Posted July 7, 2011 Author Posted July 7, 2011 Seen the Decals now,but I think I will go for the prototype. Thanks Paul
Jennings Heilig Posted July 8, 2011 Posted July 8, 2011 (edited) my error, I thought the C-121 was based on the L1049 which had a fuselage length of 116 feet. It depends what kind of C-121 you're talking about. Some were short fuselage birds and some were long fuselage birds. The C-69 designation wasn't used post-war (for some reason). It got changed to C-121A when the USAF bought some L-749s in the late 1940s. They just added letters, not bothering to change the "121" designation when Lockheed started building 1049s. Edited July 8, 2011 by Jennings Heilig
dogsbody Posted July 9, 2011 Posted July 9, 2011 This may not help your cause, but here's a B&W image of the C-69.
paul178 Posted July 9, 2011 Author Posted July 9, 2011 Thankyou dogsbody it does help a lot. It shows the demarcation between the upper and lower paint colours.
