Ozymandias15 Posted September 24, 2023 Posted September 24, 2023 Hi everybody, I have just retired and have decided to start modelling again. As it is a few years since my last build I am surprised by all the different types of glues/CA adhesives there are. As I am going to build mainly British WWII planes, I would be grateful for any help on which glue to use on cockpit transparencies to avoid clouding etc. Any info would be appreciated. Many thanks
Pin Posted September 24, 2023 Posted September 24, 2023 Rule of thumb - you don't use CA for transparencies. Thick, clean PVA is the best option IMO. Works for all kind of transparencies - styrene, vacformed PETG, resin, water dissolvable, i.e. excess can be removed with wet earbud without a trace, Future/Klear friendly, transparent when cured. As to CAs - I use Sylmasta. More pricey than CA you could find in off-licence on the corner but more predictable. Three viscosity set (thick, medium, thin) covers pretty much all my needs, costs about 20£ online. I use pure MEK for styrene, behaves pretty much as Tamiya Super Thin Cement for a fraction of the price.
Mark Harmsworth Posted September 24, 2023 Posted September 24, 2023 For cockpit transparencies definitely a white or pva is the best as it cures slowly so you have time to adjust positioning and it dries clear. Any excess can be removed with a damp cotton bud / brush / finger. Something like this: https://www.hannants.co.uk/product/MSKK I use a large bottle of 'craft glue' (also pva) that my youngest daughter left behind and used for sticking paper etc. She left home a decade ago - it lasts - if there's a decent top to stop it drying out. all the best Mark
Fin Posted September 24, 2023 Posted September 24, 2023 For clear parts, especially canopies I`m using Humbrol Clearfix: https://www.super-hobby.co.uk/products/Humbrol-Clearfix.html It`s somewhat thicker than other PVA glues I`ve tried for this and requires a bit of care when aplying so as not to add too much, but it makes for a strong bond. You can easily hold the model by the canopy and it won`t detach. The other thing to be careful about when using it is that it tends to leave a sort of threads when you take it off the bottle, sorta like melted cheese. If you`re using a cocktail stick or toothpick you need to roll it at bit to make sure no threads get to places where you don`t want them to.
