Otaki 1/144 Ye-152A Flipper - Completed
Build 18
This is a very old kit from Otaki, but it looks to be a thousand times better than their F-100D that was released around the same time. (Possibly the worst kit I've EVER worked on!) This will mainly be a OOB build with a bit of rescribing.
Price: 83p from eBay
Edited by Speedman
Cheers :)
The wing is on after a lot of dry fitting. I kept fitting it and finding the rear edge of the wings were not perpendicular to the centerline. :hmmm: It turns out that the lower fuselage section moulded to the one piece wing is out of alignment. So every time I lined the fuselage section up the wing was out! I've now aligned it via the wings but I've got to do some serious cutting & sanding to get the fuselage to line up. STILL not as bad as the F-100 ;)
I needed to weight the nose so I rolled some paper, glued the seam, plugged one end with rolled up tissue paper then soaked the plug in CA to harden it. Once my tube was made, I filled it with Liquid Gravity and CA then glued the whole thing into place through the intake.
Have I just invented the "Heavy Metal" cigarette? :lol:
Finished :) I airbrushed some silver on decal paper and feathered some black over it to make the auxiliary intake holes. My tablet's camera just makes it look like a black square :( , hopefully my proper camera will bring out the detail. I'll post some proper photos when I can.
