Sign in to follow this
Mike
Custom Activity Stream Sharing
With Activity Streams you can create your own custom searches that return these "streams" with whatever you have set it up to give you.  You can also send a Stream to anyone else just by sending them a link to your Stream results.  For example, I've created the Streams below for viewing Content of specific genres, which includes all the forums in that genre, plus all the reviews from that genre.  Have a click and you should hopefully see what I mean.  If you like those Streams, you can make them appear in your Custom Streams drop-down under the Activity tab.
Aircraft Content http://www.britmodeller.com/forums/index.php?/discover/8/
AFV Content http://www.britmodeller.com/forums/index.php?/discover/10/
Maritime Content http://www.britmodeller.com/forums/index.php?/discover/11/
Vehicle Content http://www.britmodeller.com/forums/index.php?/discover/12/
Sci-Fi Content http://www.britmodeller.com/forums/index.php?/discover/13/
Diorama Content http://www.britmodeller.com/forums/index.php?/discover/14/
Review Content http://www.britmodeller.com/forums/index.php?/discover/15/
Ready for Inspection (RFI) Content http://www.britmodeller.com/forums/index.php?/discover/40/
Work In Progress (WIP) Content http://www.britmodeller.com/forums/index.php?/discover/37/
When you click on a Stream, it will open in a new window and show you the result of that search.  It will also pop-up with a message as follows:
Quote
This is a stream created by XXXX (Mike in this instance)
Add it to your own streams for easy access in future, or to edit its filters.
There is a button on the right hand side that says Add To My Streams.  Click that if you think you'd like to have access to that in the future.  If not, just do something else :)  If you add it, it will appear in your Activity > My Activity Streams under the Custom Streams header :)
I've added two new streams for RFI & WIP content across the genres :)
