Fox_Two Posted June 21, 2021 Author Share Posted June 21, 2021 On 6/19/2021 at 2:17 PM, TheRealMrEd said: Since this hasn't been updated in a while, I thought that I would mention that there are some other detail issues with dropping the wing flaps, etc. on the Academy F-8 series. For those interested, a like to my F-8C Build will help some in that area. While some of that thread is concerned with the model conversion, or items related to the Academy F-8, in general, are noted. Ed Hi Ed, Wow, I completely forgot about this build. I ended up trashing it. I did finish it in the end but the gear bay was not set straight and caused the model to lean significantly to one side. I tried modifing the landing gear to compensate but it didn't work out quite right. That and a few other decal/small piece mishaps I just decided to toss it. The end result of the flaps modification though worked out really really well. So this thread should at least serve as a good reference for that. 1 2 Link to comment Share on other sites More sharing options...
TheRealMrEd Posted June 22, 2021 Share Posted June 22, 2021 Hi Fox_Two, I also ran into a few problems with the gear bay, the launch bridle hook area, and I was amazed that you seemed to get away with adding the upper main gear door actuating arms, without them breaking off. On my second build, I left them off until the end! Ed Link to comment Share on other sites More sharing options...
TonyOD Posted June 22, 2021 Share Posted June 22, 2021 13 hours ago, Fox_Two said: So this thread should at least serve as a good reference for that. It does. Thanks. Sorry to hear it didn't make it over the line though! Link to comment Share on other sites More sharing options...
