4 JANUARY
No EVAs on this date
(The good stuff is coming soon, I promise!)
6 JANUARY
2017 Robert Kimbrough & Peggy Whitson (ISS Expedition 50)
Duration: 6 hr 32 min
The astronauts installed adapter plates and hooked up electrical connections for three of six new lithium-ion batteries, which would replace the nickel-hydrogen batteries previously used to store electrical energy generated by the station’s solar arrays.
This was Kimbrough's third EVA and Whitson's seventh (the second female to make this number).
7 JANUARY
1991 Viktor Afanaseyev & Musar Manarov (Mir Expedition 8 )
Duration: 5 hr 18 min
This was a second attempt to repair the hatch on the Kvant 2 module, which had suffered damage to its hinges six months earlier when it was opened before the airlock was fully depressurised. The earlier repair, in October, had been unsuccessful but this time the hinge was replaced, meaning the hatch could be closed properly. The repair took around four hours, at the end of which the cosmonauts entered the module and sealed the hatch to check that it was working properly. It was then reopened and the cosmonauts left the station again for other tasks, which included moving parts and equipment for the upcoming solar array transfer EVA to Kvant 2’s exterior; removing a camera for repair inside Mir; and removing for return to Earth a space exposure cassette of superconductive materials.
This was Afanaseyev's first EVA and Manarov's fourth.
8 JANUARY
1990 Aleksandr Viktorenko & Aleksandr Serebrov (Mir Expedition 5)
Duration 2 hrs 56 min
The start of the EVA was delayed by a problem with a valve which allowed air to escape from the docked Soyuz TM-8 spacecraft when they tried to depressurise Mir's transfer compartment which was being used as an airlock. Once this was sorted out the cosmonauts installed two star trackers which had been delivered by the Kvant 2 module. They also retrieved samples from the exterior of Mir's hull.
First EVA for both cosmonauts
1998 Anatoli Solovyov & Pavel Vinogradov (Mir Expedition 24)
Duration 3 hr 6 min
There had been further problems with the Kvant 2 hatch and the cosmonauts' primary task was to carry out an inspection to determine how it could be repaired. However it was soon discovered that one of the locks was damaged and the crew were able to fix the problem without the need for a later EVA. The cosmonauts then used the Strela boom to move across Mir and recover the American optical monitoring experiment. Before closing out the spacewalk, the team also checked the integrity of cable connections to several antennas.
Solovyov's fifteenth EVA (nobody else has made more than ten) and Vinogradov's fifth.
9 JANUARY
11 JANUARY
Duration 2 hr 54 min
The cosmonauts retrieved some French exposure experiments from the exterior of the station and replaced them with new ones. They then returned to the depressurised transfer compartment at the forward end of Mir and transferred the docking drogue from the +Y port, where Kvant 2 was docked, to the -Y port opposite in preparation for the arrival of the Kristall module. This was the last use of the Orlan-DMA space-suits with power supplied through an umbilical, and also the last time the transfer compartment would be used as an airlock until 1995.
Second EVA for both men.
13 JANUARY
2017 Robert Kimbrough & Thomas Pesquet (ISS Expedition 50)
Duration 5 hr 58 min
The astronauts installed three new adapter plates and hooked up electrical connections for three of the six new lithium-ion batteries which would replace the nickel-hydrogen ones then in use. The new batteries were smaller than the old ones but still provided an improved power capacity. They also stowed padded shields outside the station to make room inside the airlock and took photographs of various items of external hardware for use in planning future spacewalks.
This was Kimbrough's fourth EVA and Pesquet's first.
14 JANUARY
1998 Anatoli Solovyov & David Wolf (Mir Expedition 24)
Duration 3 hr 52 min
Third joint US/Russian EVA. The team carried a hand-held device called the Space Portable Spectroreflectormeter (SPSM) to measure the absorption proficiences of solar equipment, mirrors and other external surfaces. Solovyov also carried out additional repairs to the Kvant 2 hatch.
This was Solovyov's sixteenth and last EVA (a record). His total time was 79 hr 51 min (also a record). It was Wolf's first EVA.
2002 Yuri Onufriyenko & Carl Walz (ISS Expedition 4)
Duration 6 hr 3 min
Completed the installation of the Strela 2 cargo crane. They used the already functional Strela 1 to transfer the new crane from its stowed location next to the Unity and Zarya tunnel and attached it to the Pirs Module. They also mounted the first of four amateur communications antennae on Zvezda.
Onufriyenko's seventh EVA; Walz's second.
2010 Maxim Surayev & Oleg Kotov (ISS Expedition 22)
Duration 5 hr 44 min
The cosmonauts worked on the Russian-built Mini-Research Module 2, known as Poisk (Search), which had been delivered by a modified Progress propulsion module the previous November, which had then separated to expose the docking hatch. The cosmonauts installed Kurs navigation antennae, cables and a docking target, and also fitted handrails to assist in future EVA work. Finally they retrieved the Biorisk experiment canister from the exterior of the station.
Surayev's first EVA; Kotov's third.
15 JANUARY
1996 Leroy Chiao & Daniel Barry (STS-72)
Duration 6 hr 9 min
The primary objective was to test equipment that would be used in ISS assembly tasks. Using a foot restraint on the end of the manipulator arm, the astronauts first attached a rigid umbilical diagonally across the Orbiter payload bay: these will carry fluid and electrical lines between the modules and truss of the station. They also tested a Portable Work Platform built by Lockheed Martin, which included toolboards and tether sockets.
First EVA for both astronauts
2003 Ken Bowersox & Don Pettit (ISS Expedition 6)
Duration 6 hr 51 min
This EVA was originally scheduled for 12 December and would have been carried out by Bowersox and Nikolai Budarin, who would have been the first Russian cosmonaut to use an American space-suit. However though Russian doctors declared him qualified for the EVA, their US counterparts decided that he was physically unfit to use the US suit and Quest airlock, for reasons unknown. Therefore Pettit replaced him and the EVA was postponed. When it finally took place the astronauts had difficulty opening the outer airlock hatch but finally emerged to begin their work programme, which included releasing ten launch restraints from the radiator system on the P1 Truss so that Mission Control could remotely unfold it to its full length of 22 metres and removing grit from the docking mechanism of the Unity module. However a jammed pin meant they were unable to install a stanchion and light fixture to an equipment cart.
First EVA for both astronauts.
2016 Tim Kopra & Tim Peake (ISS Expedition 46)
Duration 4 hr 43 min
The main objective was to replace a failed voltage regulator which had caused a loss of power to one of the station's eight power channels. This was accomplished but the EVA then had to be curtailed when Kopra reported water leakage in his helmet. A similar but much more serious incident occurred on an EVA in 2013 when Luca Parmitano experienced a major water leak. Kopra was in no danger this time but Mission Control ordered an immediate termination of the EVA.
This was Kopra's third EVA and Peake's first and only one (to date).
2020 Jessica Meir & Christina Koch (ISS Expedition 61)
Duration 7 hr 29 min
The second all-female EVA. The astronauts carried out further work in replacing the older nickel-hydrogen batteries with newer, more powerful lithium-ion batteries for the power channel on one pair of the station’s solar arrays.
Meir's second EVA and Koch's fifth.
16 JANUARY
1969 Yevgeni Khrunov & Aleksei Yeliseyev (Soyuz 5 --> 4)
Duration 37 min
When Soyuz 4 and Soyuz 5 carried out the first docking between two manned spacecraft, the Soviets described it as "the world's first experimental cosmic station with four compartments for the crew". This was something of an overstatement as this version of the Soyuz did not even have an internal transfer tunnel, so Khrunov and Yeliseyev had to perform an EVA to cross between the two spacecraft. This was only the second Soviet EVA, though it was the first involving two men. The cosmonauts sealed themselves in the Orbital Module of Soyuz 5 and depressurised it, then emerged into space. The suits had been designed using feedback from Alexei Leonov and were not subject to the ballooning that he had encountered. The life-support system was located on the chest and abdomen. Khrunov transferred to Soyuz 4 first, while the docked craft were over South America, out of radio contact with Mission Control, but they were back in touch by the time Yeliseyev crossed over. The cosmonauts entered the Soyuz 4 Orbital Module and closed the external hatch; it was then repressurised and they joined Vladimir Shatalov and presented him with newspapers reporting his own launch as proof that the transfer had taken place.
This was the only EVA for both cosmonauts.
17 JANUARY
1993  Greg Harbaugh & Mario Runco (STS-54)
Duration: 4 hr 28 min
The EVA started late because preparations took longer than expected but eventually the astronauts began rehearsing techniques for on-orbit assembly. They tested moving large objects around the payload bay by carrying each other and used a large tool to manually position the tilt table from which a TDRS comsat had been launched earlier in the mission. They also placed each other in the bracket which held the space-suit in the airlock, testing their ability to align bulky equipment accurately. Despite the late start, the EVA had to be terminated at the planned time because of the schedule of the Diffuse X-ray Spectrometer. After landing, the astronauts repeated their tasks in the WETF water tank to see how they compared with their activities in genuine microgravity.
First EVA for Harbaugh; only EVA for Runco.
1996 Leroy Chiao & Winston Scott (STS-72)
Duration 6 hr 54 min
When the EVA began, Scott mounted a foot restraint and stood still while Endeavour rolled round to take the payload bay out of direct sunlight. This was to chill the bay so that the heating system in the space-suit gloves could be tested. Scott was aware of the low temperature, but did not find it uncomfortable. He later said that if he had been busy and moving around, he would have been even warmer. Once this experiment was complete, the astronauts tested cable trays and clamps that would be used on the ISS. They also rocked back and forth on the foot restraints to determine the level of stress likely to be placed on the ISS structure during assembly and maintenance tasks.
Chiao's second EVA; Scott's first.
19 JANUARY
20 JANUARY
Duration 6 hr 58 min
Third all-female EVA. The astronauts completed the task of replacing the old nickel-hydrogen batteries with lithium-ion ones. The outmoded batteries were stored on an external platform until they can be disposed of aboard a Japanese cargo freighter due to visit the station later this year. The USA was observing Martin Luther King Day and at the end of the EVA the astronauts paid tribute to him. Meir said he was a personal hero and looking down on planet Earth reminded her of his words: “We may have all come on different ships, but we’re in the same boat now.” Koch noted how much is owed to those who worked for civil rights and inclusion and “paved the way for not only us, but so many who have a dream.”
This was Meir's third EVA and Koch's sixth. Koch has no further EVAs scheduled before she returns to Earth: her total time is 42 hr 15 min.
21 JANUARY
2011 Dmitri Kondratiyev & Oleg Skripochka (ISS Expedition 26)
Duration 5 hr 23 min
Objectives on this EVA were to complete the installation of a new high-speed data transmission system, remove an old plasma pulse experiment, install a camera for the new Rassvet docking module and retrieve a materials exposure package. A previous attempt to install the camera in November (by Skripochka and Aleksandr Yurchikhin) had been unsuccessful because of the thermal insulation next to its mounting bracket, so the cosmonauts used a special cutter to rip the threads on some of the insulation material to expose it. Once the camera was installed, they mated the camera’s cable to a pre-wired connector that would route the video into the station. Before the EVA began, ISS Commander Scott Kelly and Flight Engineer Alexander Kaleri boarded their Soyuz TMA-01M spacecraft, which was docked to the Poisk module on the opposite side of Zvezda from the airlock, and sealed the hatches between Zvezda and Poisk. This protected against the unlikely possibility of a sudden station depressurisation and also meant that the forward portion of Zvezda could be used as a backup airlock if necessary. The remaining Expedition 26 crew members, Cady Coleman and Paolo Nespoli, were in the US segment of the station and had access to their Soyuz TMA-20 spacecraft, which was docked to the Rassvet module adjacent to Pirs on the Zarya module; therefore there was no need for such a precaution.
Kondratiyev's first EVA; Skripochka's second.
23 JANUARY
1991 Viktor Afanaseyev & Musa Manarov (Mir Expedition 8)
Duration 5 hr 33 min
Main task was to install the 45 kg telescoping Strela boom to the exterior of Mir, locating it on one of the attachment points that had held the payload shroud during launch. The primary purpose of this boom was to move solar arrays from Kristall to Kvant but it would also be used to transfer cosmonauts and equipment around the station, and as a mobile handrail. Originally the installation was to have been conducted over the course of two EVAs but they were combined, resulting in this one lasting nearly two hours more than planned. The boom was tested by Afanaseyev operating its controls while Manarov rode on the end. Before ending the EVA the cosmonauts retrieved the Ferrit space exposure experiment and replaced it with Sprut-5, intended to measure particle flow.
Afanaseyev's second EVA; Manarov's fifth.
2018 Mark Vande Hei & Scott Tingle (ISS Expedition 54)
Duration 7 hr 24 min
The astronauts replaced a Latching End Effector on the station's manipulator arm. This had been causing problems because the cables which snare the target objects had been showing evidence of degradation.
Vande Hei's third EVA; Tingle's first
