Ale85 Posted January 21, 2012 Share Posted January 21, 2012 Hi guys, yesterday i bought the Hasegawa's box for the yellow sea king in RAF SAR version, but i wont to convert it in a HAR.5 Royal Navy Sea King to make a grey and red beast... something like this: the best problem is the different radome... which is the best conversion for the HAr.5? Can i use the Flightapth HAr.6 conversion?? thanks in advance ciao Ale Link to comment Share on other sites More sharing options...
smeds Posted January 21, 2012 Share Posted January 21, 2012 You can use the HAR.6 set, it contains all you need apart from decals, which are available from Model Alliance Link to comment Share on other sites More sharing options...
Ale85 Posted January 21, 2012 Author Share Posted January 21, 2012 Thanks so much! The M.A. set is already in my stash!!!! ciao Ale Link to comment Share on other sites More sharing options...
Wafu Posted January 21, 2012 Share Posted January 21, 2012 Hi Ale85 The Royal Navy converted to Mk6's from the early 90's so you can build the 771 Search and Rescue a/c using the Mk6 set. The only changes from Mk5 to Mk6 was the avionics so refer to referance pictures when selecting an aircraft to model. You should also be aware that RN Sea Kings now operate with the new Carson Five Blade Tail Rotor and not the Six Blade that was standard when I worked on the aircraft. Again referance being the key. I know you live in Milano but do you know of any good model shops in Rome? I will be in Frozinonie in a few weeks and may be able to get to Rome on the Saturday. Good luck with the build. The Woo. Link to comment Share on other sites More sharing options...
Ale85 Posted January 21, 2012 Author Share Posted January 21, 2012 Hi Ale85I know you live in Milano but do you know of any good model shops in Rome? I will be in Frozinonie in a few weeks and may be able to get to Rome on the Saturday. The Woo. thanks for the answer! Sadly i don't know any model shop in Rome; but you can take a look to this LINK where you can find some models shops in Rome!!! ciao Ale Link to comment Share on other sites More sharing options...
Windy Posted January 21, 2012 Share Posted January 21, 2012 (edited) Hi Ale85The Royal Navy converted to Mk6's from the early 90's so you can build the 771 Search and Rescue a/c using the Mk6 set. The only changes from Mk5 to Mk6 was the avionics so refer to referance pictures when selecting an aircraft to model. You should also be aware that RN Sea Kings now operate with the new Carson Five Blade Tail Rotor and not the Six Blade that was standard when I worked on the aircraft. Again referance being the key. I know you live in Milano but do you know of any good model shops in Rome? I will be in Frozinonie in a few weeks and may be able to get to Rome on the Saturday. Good luck with the build. The Woo. Carson blades are only for Afghan aircraft and are not for the UK and are not used on SAR cabs. To make a Mk.5 you just need the AEW boxing and a larger radome (ask Dave at flightptath he might supply it on it's own). Edited January 21, 2012 by Windy Link to comment Share on other sites More sharing options...
Wafu Posted January 23, 2012 Share Posted January 23, 2012 Carson blades are only for Afghan aircraft and are not for the UK and are not used on SAR cabs.To make a Mk.5 you just need the AEW boxing and a larger radome (ask Dave at flightptath he might supply it on it's own). I agree with Windy, Dave at Flightpath is very helpful. Link to comment Share on other sites More sharing options...
