Mike Posted October 6, 2023 Share Posted October 6, 2023 Mercedes-Benz Unimog U1300L TLF 8/18 (07512) 1:24 Carrera Revell The Unimog U1300L is based on the 435 chassis, although the original U1300 was built on the different 425, and sibling the 1700L is also based upon the 435. It was introduced as a specialist fire engine for the German Fire Service and the Bundeswehr staring in 1975, and by the time it was retired in 1987, under a thousand U1300 and over 21,000 U1300L has been produced. The L variant used the enhanced 435 chassis and has a more powerful engine to improve its traction and load-carrying capabilities, with a choice of two lengths within the designation, driven from the rear wheels with selectable four-wheel drive for rough or muddy terrain. A straight six-cylinder diesel engine provides the power, sometimes with a turbocharger, and that power is put down through two or four wheels via an eight-speed gearbox that gives it a top speed of just under 70mph for an empty vehicle. Speaking of load, it can carry up to 1,800 litres of fire-fighting water supply to make a start on remote fires, and has a capacious load area that can be stacked with fire-fighting equipment and supplies, accessing them via large lift-and-retract doors on the sides and rear of the vehicle, a fenced-off roof area for more equipment and a ladder, and seating in the cab for three crew. The roof of the cab is the location for the blue flashers and the siren horn, with a movable search-light at the top of a post on the bonnet, as fires don’t just happen during daylight hours, although they do bring some of their own illumination. It was replaced by a 437 based truck that is still in service today. Incidentally that same chassis is also the basis for the Dingo 2 MRAP Armoured Vehicle. The Kit This kit is a reboxing of a kit from Revell that was first released in 1985, with new parts being added during the remainder of the 80s. The kit arrives in a large end-opening box with a painting of the kit in front of a burning building of some type, with a few fire-fighters seen in the background in their hi-viz protective gear and helmets. Inside the box are five sprues in styrene, two in red, one each in silver, black and white, plus a clear sprue, four flexible black tyres, a small piece of widely spaced mesh, a large decal sheet, and the instruction booklet that is printed in colour with profiles at the rear for the marking options. It is of course a product of its time, but still has some good detail where it counts, although there are a few moulded-in tools that would have benefitted from separate parts when looking at it from a modern perspective. There isn’t any mould damage visible, and a tiny amount of flash is relegated to the sprue runners, so shouldn’t be an issue. Note: The red sprue photos have been processed to reveal more of the detail, as they were a little bright. Construction begins with something you wouldn’t necessarily expect of a kit from the 80s, which is an engine. The big inline block is built from two halves and includes the sump, adding the serpentine belts with alternator to the front, and a depiction of the turbo on the left side. The chassis is moulded as a single large part, adding some ancillaries, the engine, drive-shaft, transfer box with additional drive-shafts moulded-in, and the exhaust muffler with exit pipe and feeder pipe that links to the engine in the front. The front suspension mounts are each made from two-part springs with rubber covers and connections on the bottom that accepts the seven-part front axle with pivoting hubs that have brake discs and callipers moulded-in. Additional struts, dampers and anti-roll bars are fixed to the axle, and a steering linkage ensures that the two hubs move in unison, providing you haven’t overdone the glue on the pivots. The rear axle is supported by another pair of covered springs, but its assembly is more complex and rugged to support the weight of the rear of the vehicle. The two assemblies are slipped over a transverse beam near the rear of the chassis, then the four-part rear axle is fitted, with two cross-braces, dampers, anti-roll bars and ancillaries layered over it. Two hydraulic reservoirs and their hoses join them together, then the assembly is attached to the chassis just forward of the rear axle, with more parts around them, adding fuel tank, foot-steps, stowage boxes and a rear cross-beam with towing shackle and reversing lights, one on the beam, the other on a bracket to the side. The vehicle’s wheels are each made from two hub halves that hide a mushroom pin to attach to the axle, and a rubber tyre is slipped over the completed hub, all of which requires no glue. The cab is a single part that is created via sliding moulds to produce all four sides in one part including detail, minus the doors and windows, with a pair of support beams that must be nipped off from the door openings, ready for the installation of the doors later. The two seats are moulded from two parts each, consisting of the upper pencil-quilted portion, and the base with integrated rails, one seating two on a wider cushion, while the driver gets his own individual seat. The cab floor is detailed with foot pedals, gear and drive shifting levers added to the centre, and the dash perched atop the centre console, applying four decals over the painted part before it is installed. The seats are mounted on the rear of the floor, the steering wheel and column are inserted, and another two decals are applied to the ends of the dash panel. Starting with the cab body inverted, the front grille is fixed under the bonnet, the windscreen slips in from inside, and a rear-view mirror is added to the centre, then building up the doors with door cards, fixed quarter-light, and a three-part hinge that is selectively glued so they remain mobile. They are glued at the front edge by the hinges, taping them into position until the glue dries. The cab is then lowered over the interior, adding a detail insert with ribbed roof and circular panel over the recessed top. The details are then applied, including the siren horn, a three-spoked circular part, and the blue lights on the front corners of the roof. Two small panels over the front wheels are inserted on the sides, with arches mounted on pegs from below. The load area is a complex assembly, starting with the partially tread-plated floor, adding four sides, taking care to mount the floor above the supporting lip inside each face. The internal dividers create four compartments, with moulded-in equipment, some of which are surprisingly deeply recessed to add realism, with a few that aren’t quite so good. Additional equipment, including rolled-up hoses, a simple cot, and the two up-and-over doors are inserted into the visible compartments on the right side, then some more details are added. This includes fire extinguisher, manifolds, nozzle, another hose, and a trio of yellow containers, which are fitted under the moulded-in hose racks, one of the more impressive moulded-in portions of the interior. The roof is fitted, and each side is edged by a length or double railings, fixing an extending five-part ladder into position along one side, and a vertical roof ladder that is moulded from vertical and horizontal sections, plus two mounts that fit on pins to the back of the vehicle and extends onto the roof for ease of access. The rear light cluster has clear lenses, hanging on a single stalk under the back of the vehicle, joined by a pair of lollipop reflectors on the corners, and number plate with light on the left side. Turning the body over, supports and pivots are inserted into location guides, then are joined by four mudguard halves, which will help when gluing the body on the rear of the chassis, adding the cab to the front, then making up the front bumper, which has the reflectors moulded-in for the running lights, fitting clear lenses over the top, and cutting two pieces of the supplied mesh to 7mm x 14mm to act as their protective cages. The vehicle is essentially complete, although the cab exterior needs detailing, adding the two wing-mirrors on large C-shaped mounts, the searchlight with clear lens on the scuttle in front of the windscreen, a pair of separate wipers, two grab-handles for access to the bonnet area, and two contoured clear indicators that should be painted clear orange. Markings There are a surprising eight decal options included on the sheet, but you’d be safe in guessing that the predominant colour is red. There are however TWO different reds, depending on which option you choose, so make your choice early, as you will have to apply some red paint to the exterior during the building process. From the box you can build one of the following: Trier, Germany Bad Oeynhausen, Germany Höxter, Germany Braunschweig, Germany Venlo, Netherlands Salzburg, Austria Switzerland, Altstätten Hasselt, Belgium Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas. Conclusion It’s an older kit, but it checks out. With careful painting and detailing, this should build up into a creditable replica of this workman-like fire-engine that saw extensive service in Germany and Europe. Highly recommended. Carrera Revell model kits are available from all good toy and model retailers. For further information visit or 2 Link to comment Share on other sites More sharing options...
richellis Posted October 7, 2023 Share Posted October 7, 2023 Cannock Fire station has a unimog on active service, slightly facelifted cab with an anglico body on a 2011 plate. think Staffs have a few so would be a good conversion if you want a British appliance Link to comment Share on other sites More sharing options...
