Mike Posted December 7, 2022 Share Posted December 7, 2022 Unimog 2T MilGl (03337) 1:35 Carrera Revell Unimog was the brand-name used by Mercedes for their truck, tractor and commercial vehicle range that began post WWII as an agricultural brand, initially built by another company for them whilst using their engines. The name derives from a portmanteau of “UNIversal-MOtor-Gerät”, or Universal Motor Machine literally translated. The range broadened in the late 40s and early 50s to include trucks, of which the 404 series was one, entering production in 1955. It is a small (1.5 tonne) 4x4 truck that was driven by a 2.2 litre M180 straight-6 Mercedes engine and has impressive off-road performance due to a change that had been required by a customer, the French Army, who wanted the spare tyre to be stored clear of the load compartment. The designers altered the shape of the rear chassis rails to allow the wheel to sit under the floor, the downward sweep giving the chassis extra flexibility that smoothed the ride on rough surfaces, assisted by coil springs, rather than traditional leaf springs. The four-wheel drive system could be disengaged on smoother ground, leaving just the rear wheels engaged, thereby saving fuel and wear on the front drive-shafts, and generally improving performance all round. The 400 series was the most numerous of the Unimog line, and was available as a short or long-wheelbase chassis, with the shorter option phased out at the beginning of the 70s, while the longer wheelbase continued on for another decade before it too was retired. The 437 was introduced late in the 19880s and is more of a heavy-weight that is modernised and continued to be upgraded as time went on. It is easily discerned by the squared off cab, and is available in U and L derivatives, standing for short and long wheel-bases respectively. Many variants are used by the post WWII German Bundeswehr, the 2T MilGl being one of them, certified for a load of, you guessed it, two tonnes, with a load bed that has a canvas tilt to protect the load whether it is equipment or soldiers. A total of over 62,000 of the 404S were made over its lengthy production run, with many of them still on and off the roads to this day due to their rugged engineering. The Kit This is a reboxing of the original kit that was tooled in 1995, and although it is heading toward 30 years old, it has decent detail throughout, although there are doubtless some areas that the more detail-oriented modeller might want to upgrade. It arrives in a slim end-opening box, and inside are four sprues and a cab in pale greenish grey styrene, a flexible sprue containing five sturdy tyres, a clear sprue, the instruction booklet in the old-skool Revell style on matt paper with a rough texture that invites comparison with cheap toilet paper. Ouch! It’s a product of its era in this respect, and the instruction steps are also monochrome, as are the painting and decaling guides in the rear. You get a full engine and chassis, plus drive train representations in the kit, as well as the expected cab interior, so it’s a great canvas to work your wonders upon, whether you’re an out of box modeller or otherwise. Construction begins with the engine, which I suspect is the straight 6-cylinder 5958cc diesel engine, judging by its tall, narrow appearance. The two block halves are brought together, then detailed with the complex belts at the front, and some ancillaries on the side. The motor is dropped into the front of the ladder chassis after adding a dropped hook, then the drive-shaft to the rear is inserted into the back of the engine, linking into the two-part transmission with a further drive-shaft heading back to the rear axle. The tubular muffler and short exhaust pip are fitted to a nub on the left side of the chassis, with the long snaking pipe linking the box to the engine and painted a grubby, rusty colour. The big front springs are made up from the two halves and a bottom cap, and these mount on the circular protrusions from the sides of the chassis, ready to accept the front axle, which has disc brakes on pivots installed in it during closure, then detailed with various steering and suspension links. Similar two-part springs are made up for the rear and mounted on large pivots top and bottom, then slipped over the rod passing through the chassis. This allows the rear axle to be made up with disc brakes at each end and inserted into the bottom of the suspension unit, again getting suspension links and a pair of shocks to improve handling during off-road adventures. A pair of cylinders and their associated hoses are attached in front of the rear right wheel, with another shorter one inside the chassis rail, which looks like the air brake system, as it includes a four-port manifold in the hose area. The fuel tank and a stowage box are each built from two parts, and the former has the mount moulded-in and a cap fixed to the top, while the latter is mounted on a separate bracket so both can be installed on the right chassis rail between the wheels. A foot peg and another on the other side are fixed in front of these items, with an empty bracket just behind it on the left side. At the rear of the chassis the light clusters are built up on L-shaped brackets, with clear lenses that need painting with appropriate clear shades, and finally the four flexible black tyres can be installed on the axles, after adding the two hub halves and a free-wheeling cuff in the centre, gluing them carefully if you want the wheels to rotate. The cab is begun with the floor, adding the three pedals in the left foot well, and the dash board with decals plus the gear and handbrake levers in the centre console. The driver has a separate seat, with a wider one for the co-driver that could seat two, and both have pencil-roll upholstery moulded-in, mounting on two raised lines in the floor. Finally, the steering column with stalk and separate wheel is inserted into a hole in front of the pedals, completing the interior. The cab outer is moulded separately with what must have been early sliding moulds, creating a five-sided part that just needs doors windscreens and a roof panel. The radiator grille is a separate part too, and is first to be glued to the front of the cab, with the windscreen and rear-view mirror following it. The two doors are prepared by adding three-part hinges, a quarterlight and the door card with two decals on one, one on the other. These are then inserted into the cab, and is joined by the ribbed roof panel, which repeats the hole for the machine gun ring, and also has a small hatch added to the left wing, plus a snorkel for deep-water wading on the right side, after which it can be mated to the cab interior. The machine gun ring on the roof has a circular hatch, a raised ring, and a depiction of the MG3, which is a direct descendent of the fearsome MG42. Underneath, the inner wings are glued to the cab floor, and a pair of crew steps hang from the sides under the doors on a pair of pins. The load bed is moulded with the tilt erected, and the four sides have the short upstands moulded-in, and also have some creasing of the canvas engraved into the surface. Some of the creases would benefit from softening, but that’s entirely your choice. The four sides are topped off with the roof, and then the floor, which has no detail on the top, but with the benefit of some quick research, that’s not too far from accurate. The first (and only) picture I found of the inside has one single panel line running transverse about a third of the length from the front, which shouldn’t be too hard to replicate, even if you only have a needle. Not very grippy though! Bear in mind that was a slightly non-standard dual cab variant, so further research might be in order. Inverting the load area allows you to add the various ribs and stringers, plus stowage boxes, four mudflaps, and more stowage behind them, and a rack for fuel cans near the front on the right. The cab and chassis are mated, using up the fifth tyre and hub parts to put a spare on the bracket installed on the chassis rail earlier, then the load bed is also mated with the rear of the chassis. A shield-shaped part is fixed to the rear bumper iron with added decals, then the front bumper has two lights inserted in recesses and fitted to the front of the vehicle. The cab then has windscreen wipers, a number of grab-handles and some corner lights fixed to the bonnet, with a pair of large wing mirrors attached to each door. Between the cab and load area, a shallow “spoiler” is glued onto the back of the roof to smooth the airflow between the two parts of the vehicle, and a curved plate is attached to the back of the machine gunner’s position on the roof. Now for the paint. Markings There are four decal options included on the sheet, although the diagrams are all monochrome, relying on black, white and half-tones to replicate the three colour NATO camouflage for some of the vehicle and two of the tilts. From the box you can build one of the following: 4./Panzerbatallion 33 (Green, Brown, Black Camo all over) 3./Wachbatallion BMVg, Siegburg, 2007 (Green, Brown, Black Camo, green tilt) ISAF, Kabul, Afghanistan (Sand chassis, Sand, Brown, Black tilt) Königlich Belgische Armée, 2004 (Dark Green) Decals are by Zanchetti, which is a guarantee of good registration, sharpness and colour density, with a thin matt carrier film cut close to the printed areas. Conclusion It’s not the newest kid or kit on the block, and neither are the instructions, but it’s a solid kit of this Bundeswehr staple that has been through many changes through the years. Recommended. Carrera Revell model kits are available from all good toy and model retailers. For further information visit or 3 Link to comment Share on other sites More sharing options...
bootneck Posted December 8, 2022 Share Posted December 8, 2022 Good review Mike. Any information as to whether the version in this kit was the type used by Argentinian forces in 1982, during their occupation of the Falkland Islands? cheers, Mike 1 Link to comment Share on other sites More sharing options...
Mike Posted December 8, 2022 Author Share Posted December 8, 2022 8 hours ago, bootneck said: Any information as to whether the version in this kit was the type used by Argentinian forces in 1982, during their occupation of the Falkland Islands? Not a clue dear. If you can find out whether it's a Unimog 437, you'd be close. Link to comment Share on other sites More sharing options...
