AnonymousDFB1 Posted May 1, 2010 Posted May 1, 2010 (edited) Well I must be mad! I was going to enter a 1:72 female tanks, but my brain has given up trying to reason with my heart and I picked this up at Cosford for £5.99 from Chris at Kits Kits. After my attempt to build a Gladiator for the Finnish GB (I will go back to it and finish it before the end of the GB) I'm going to torture myself a little more. I'm not going to attempt to use any of Bobs magnificent buckles but use fishing line stuck in holes for this one. Wish me luck? The obligatory box shots Not much in the box is there? Should be starting sometime this weekend Edited May 9, 2010 by Mish
Takamota Posted May 1, 2010 Posted May 1, 2010 Nice one Mish. Should look great when finished. Good luck!
AnonymousDFB1 Posted May 3, 2010 Author Posted May 3, 2010 Well the cat knew it was Monday but not a Public Holiday so she had me up early, still it allowed me to get an early start. First off I started preparing some of the parts. Struts One has a base coat of Tamiya the other has been over painted with Burnt Umber oil paint Both done but need a little more work I think Next was to cut the slots in the tailplanes for the control cables One done Second one half done Both done Engine painted and started to weather with some thinned Tamiya Smoke Prop beginning to look like wood Cockpit ready for assembly And assembled In the fuselage Fuselage halves together A little smear of filler required Engine and cowl fitted Wings and tailplane drilled ready for rigging And test fitting the lower wing Move later
AnonymousDFB1 Posted May 3, 2010 Author Posted May 3, 2010 This afternoons progress Lower wing and tailplane on Rudder in place and holes 'bunged up' ready for spraying It's silver! Ones side's decals nearly done Upper wing decals done More next weekend...
T-Tango Posted May 3, 2010 Posted May 3, 2010 Thats looking very good Mish, pretty rapid build as well, you could have another 6 or 7 done by the time the GB ends.
AnonymousDFB1 Posted May 3, 2010 Author Posted May 3, 2010 I think I'll stop at one thanks Pete. I've very pleased with the progress.
Bobs_Buckles Posted May 3, 2010 Posted May 3, 2010 I think I'll stop at one thanks Pete. I've very pleased with the progress. bleedin' 'ell! ...... Go girl! Nice work, mish. BB
T-Tango Posted May 3, 2010 Posted May 3, 2010 I think I'll stop at one thanks Pete. I've very pleased with the progress. Go, go, Mish you know you can do it.
ollieholmes Posted May 7, 2010 Posted May 7, 2010 Thats looking very nice Mish. What are you using to do the silver?
AnonymousDFB1 Posted May 7, 2010 Author Posted May 7, 2010 Thats looking very nice Mish. What are you using to do the silver? Thanks Ollie, I used Citadel Chainmail and Boltgun.
Fmk.6john Posted May 7, 2010 Posted May 7, 2010 Blooming heck Mish, a lovely speed build you got going there............. Regards, JB.
AnonymousDFB1 Posted May 7, 2010 Author Posted May 7, 2010 Blooming heck Mish, a lovely speed build you got going there.............Not a speed build John, just a very simple kit that so far falls together
Fmk.6john Posted May 7, 2010 Posted May 7, 2010 Looking good all the same Mish, if you got your mojo going and the kit falls together then it's all good! Regards, JB.
AnonymousDFB1 Posted May 8, 2010 Author Posted May 8, 2010 So this mornings progress Last few decals on and starting with the wing supports Top wing on And the first rigging wire in Now's a good time to stop for lunch More later...
AnonymousDFB1 Posted May 8, 2010 Author Posted May 8, 2010 This afternoons progress... One wing rigged and then I sort of forgot to take any more pics till I got to this stage Just got the U/C and tail rigging to do More tomorrow...
AnonymousDFB1 Posted May 8, 2010 Author Posted May 8, 2010 Thanks John, I've just found some pics on the interweb and I need to add two rigging wires to each wing. Eduard got it wrong on the instructions.
AnonymousDFB1 Posted May 8, 2010 Author Posted May 8, 2010 Grrrrr, I've just found some pics on the interweb and I need to add two rigging wires to each wing. Eduard got it wrong on the instructions.
Antoine Posted May 9, 2010 Posted May 9, 2010 Le Nieuport du Père Dorme! S/lt René Dorme, aka "Père" Dorme. 23 kills, 28 probables. KIA on may 25th 1917, in the Fort de la Pompelle sector, near Reims, Champagne. Very well done, Mish. Here's a linky for you.
AnonymousDFB1 Posted May 9, 2010 Author Posted May 9, 2010 Many thanks Antoine, You have saved me some searching as this afternoon I planned on finding out about S/lt René Dorme There's a lot to read, lets hope google can translate it all for me.
Antoine Posted May 9, 2010 Posted May 9, 2010 Shouldn't be too difficult. Let me know if you need help.
AnonymousDFB1 Posted May 9, 2010 Author Posted May 9, 2010 Shouldn't be too difficult.Let me know if you need help. Thanks Antoine, Google has done it's stuff and I can read most of the site.
AnonymousDFB1 Posted May 9, 2010 Author Posted May 9, 2010 Readable Antoine Right this afternoons progress and she's finished My first biplane in 27 years! Extra rigging lines done that Eduard forgot about and the U/C rigged. And finished Final pics in RFI and the Gallery in a while. Thanks for looking and your support during the build.
