I would like to enter this a/c, for the GB, it will be oob. build with the panzerschreck added from Kora models.
As you all know on a Hasegawa you just shake the box and then the models is finished ^_^ , so very straight forward, the tricky bit will be the fitting of the kora parts, they are quite small and fiddly.
so started.
removal of the cartridge chutes, for the F wich had no outer guns
Jes
Edited by Touvdal
Welcome on board Jes.
As Rowan says, its nice to see an 'F' ground attack in the GB.
Looking forward to seeing how the Kora stuff goes together.
Steve
Yes be nice to watch this unfold. These Panzerschreck equipped 190s have almost gained mythical status!
started to put this exelent kit together, and the fit is great, as you can see here of wing joint to the fuselage dry, no filler needed. and nearly no work need to get the nice fit.
cheers
Jes
Gear on
I have discovered that it is the Ps. 1 that i have to use, but the kora is the Ps 2., so will have to scratch build the Ps. 1.
started here using plastic tube that i have to slice up to make gab in tube.
cheers
Jes
  • 4 weeks later...
  • 4 weeks later...
