Brunswick LF-1 Zaunkonig - Need some help please
diamant
Hi,
My father is finishing our Tiger Moth series and I have started to look for our next projects.
We are very close to achieving one of the key points in our goal which is building all the German aircraft used or tested by the British / Commonwealth with the "new" markings applied. We have done 137 models and these are the missing ones (we still have to do a final check)
- B&V222  We only have one kit and there are two options.
- Junkers 352 We have two kits which is enough (next on the queue)
- Junker 52 We have 6 kits (not sure if it will be enough)
- Junker F13 We have one model to build.
- Brunswick LF-1 Zaunkonig (On the line)
- Junker 86 We have 5 kits to do (SAAF).
My father has started with the Brunswick LF-1 Zaunkonig but we only have some references from the internet.
https://www.a-e-g.org.uk/zaunkoenig.html
Whats-App-Image-2024-02-25-at-19-30-21.j
Does anyone could help us with the colour?. Which could have been the colour applied? I am referring to the photos with the RAF markings applied.
Thank you very much
Santiago
PD: This is the list of the models done so far
ARADO  Ar 96 B Air Minister 120 435 DSRU
ARADO  Ar 196 A3 W Nr 1006 No. 333 (Norwegian) Squadron Royal Air Force
ARADO  Ar 196 A3 VM748
ARADO  Ar 232 B0 Air Minister 17
ARADO  Ar 234 B-2   Air Minister 24
ARADO  Ar 234 B-2   VK877 Air Minister 26
ARADO  Ar 234 B-2   AR234 Air Minister 226
BLOHM AND VOSS Bv 138
BUCKER  Bu 131 B --- 1941
BUCKER Bu 181 C-1 Bestmann W Nr 4022 VM 215
BUCKER Bu 181 C-1 Bestmann ---
BGA 338 Minimoa ---
DORNIER  Do 17 ex Yugoslavian Dk 17 --- 1941
DORNIER  Do 22 306 No. 2 (Yugoslav) Squadron under the control of No. 230 Squadron 1941-1942
DORNIER  Do 24 T  Early 1946
DORNIER  Do 24 T
DORNIER  Do 217 M-9 AM 7, WkNr 0040 ---
DORNIER  Do 217 M-1 AM 107 W Nr 56158 ---
DORNIER  Do 217 M-1 AM 106, W Nr 56527 ---
DORNIER  Do 335 A-1 Pfeil ---
DORNIER  Do 335 A-12 Anteater ---
FIESELER   Fi 156 C-3 Storch Air Min 99 --- 1945
FIESELER   Fi 156 C-3 Storch NM+ZS No. 3 Squadron RAAF ---
FIESELER   Fi 156 C-3 Storch HB
FIESELER   Fi 156 C-3 Storch Desert Air Force Communication Fligh, February 1943
FIESELER     Fi 156 C-3 Storch VP546
FOCKE ACHGELIS Fa 223 E Drache --- Airborne Forces Experimental Establishment (AFEE) ---
FOCKE ACHGELIS Fa 330 --- Airborne Forces Experimental Establishment (AFEE) ---
FOCKE WULF  Fw 58 C-2 Weihe TE+BK  AM117 --- January 1946
FOCKE WULF  Fw 189 A3 WNr 0173 --- August 1945.
FOCKE WULF  Fw 190 A D - MP499 (P) --- --- From July 1942 to January 1943
FOCKE WULF  Fw 190 A EA/4 - PN999 --- ---
FOCKE WULF  Fw 190 F-8 U/1 Air Min 29 --- --- sep-45
FOCKE WULF  Fw 190 A-5 W Nr 52596 White 6 ---
FOCKE WULF  Fw 190 SAAF
FOCKE WULF  Fw 190 XM-? No. 182 Squadron RAF ---
FOCKE WULF  Fw 190 PE882 --- 1945
FOCKE WULF  Fw 190 F-8 / R15 AM111
FOCKE WULF  Fw 190 A8 YO No. 401 Tactical Fighter Squadron RCAF ---
FOCKE WULF  Fw 190 F-8 H
FOCKE WULF  Ta 152 H Air Min 11 ---
FOCKE WULF  Ta 152 H W Nr. 150003 --- may-45
FOCKE WULF  Fw 200 Condor G_AGAY --- --- 15/5/1940
FOCKE WULF  Fw 200 Condor GC AE AM94 ---
GOTHA   Go 145 C BV207 ---
GOTHA   Go 145 C ---
GOTHA     Go 150 ---
HEINKEL   He 111 H ---
HEINKEL   He 111 H AW177 ---
HEINKEL   He 115 C-1 BV186. ---
HEINKEL   He 162 Salamander W.Nr, 120235. Air Min 68 --- 1945
HEINKEL   He 162 Salamander W.Nr. 120076 Air Min 45 and then VH523 --- 1945
HEINKEL   He 162 Salamander W.Nr. 120072 --- 1945
HEINKEL   He 177 A-1 ---
HEINKEL   He 219 Uhu AIR MIN 20 ---
HEINKEL   He 219 Uhu AIR MIN 22 ---
HENSCHEL   Hs 126 OK No. 450 Squadron RAAF ---
HENSCHEL   Hs 129 B-1 NF756 ---
JUNKERS   Ju W 34 F. Of. John Foster y F. Lt. Hughes jun-45
JUNKERS   Ju 86 P AM118 - DDGE ---
JUNKERS   Ju 87 B-1 HK027 ---
JUNKERS   Ju 87 D3 AK ? No. 213 (Ceylon) Squadron RAF --- nov-42
JUNKERS   Ju 87 D8 VZ? No. 412 Squadron RAF
JUNKERS   Ju 87 D5 DN+LT No. 212 Squadron RAF --- may-43
JUNKERS   Ju 87 B-2 W.Nr. 5763,, 101, Autonomo Gruppo Bombardamento a Tuffo, Derna (Libya) summer of 1941 209 squadriglia --- Summer 1941
JUNKERS   Ju 87 D UF No. 601 Squadron RAF ---
JUNKERS   Ju 88 TS472 ---
JUNKERS   Ju 88 PJ786 ---
JUNKERS   Ju 88 TP190
JUNKERS   Ju 88 CV No. 3 Squadron RAAF
JUNKERS   Ju 88 622983 4R+RB ---
JUNKERS   Ju 88 WNr 0660 Coded 1H+MN ---
JUNKERS   Ju 88 HK959
JUNKERS   Ju 88 Air Min 16
JUNKERS   Ju 88 Air Min 48 ---
JUNKERS   Ju 88 HM509
JUNKERS   Ju 88 EE205 coded EA 9
JUNKERS   Ju 88 AX919
JUNKERS   Ju 88 71+CV Air Min 41 --- --- 1945
JUNKERS   Ju 188 280032 ---
JUNKERS   Ju 188 327 ---
JUNKERS   Ju 188 ---
JUNKERS   Ju 188 ---
JUNKERS   Ju 290 A-5 Seeadler 9V+B --- August 1945
JUNKERS   Ju 388 Air Min 83 ---
KLEMM Kl 35 ---
MESSERSCHMITT     Bf 108 B-1 DK280 (Wnr2039) --- --- 1941
MESSERSCHMITT     Bf 108 D R2101 --- --- 1945
MESSERSCHMITT     Bf 108 D --- No. 401 Tactical Fighter Squadron RCAF --- 1945
MESSERSCHMITT     Bf 108 B Taifun 124W 5 Second Tactical Air Force (2TAF) --- 1945
MESSERSCHMITT     Bf 108 B Taifun --- --- --- 1945
MESSERSCHMITT     Bf 108 B Taifun --- --- --- ---
MESSERSCHMITT     Bf 109 (E-3)   44 ---
MESSERSCHMITT     Bf 109 E 2 ---
MESSERSCHMITT     Bf 109 G-14 “Black 10” 2110 ---
MESSERSCHMITT     Bf 109 G-6 - U2 (White 16). TP814 ---
MESSERSCHMITT     Bf 109 F4 White 6 ---
MESSERSCHMITT     Bf 109 G 14 AS “Black 4” ---
MESSERSCHMITT     Bf 109 G 14/U4 VD358 Wk 415460, ---
MESSERSCHMITT     Bf 109 G2 EY
MESSERSCHMITT     Bf 109 G2 GL-? No. 5 Squadron SAAF ---
MESSERSCHMITT     Bf 109 ---
MESSERSCHMITT     Bf 109 E-3/B "Black 12" W.Nr 4101 de la 2./JG 51 - ---
MESSERSCHMITT     Bf 109 AE479 ---
MESSERSCHMITT     Bf 109 CV-V   No. 3 Squadron RAAF ---
MESSERSCHMITT     Bf 109 E-3 White 1 WMr 1304 ---
MESSERSCHMITT     Bf 109 G-14 /U4 W.Nr. 415460 ---
MESSERSCHMITT     Bf 109 F2 W.Nr 12764.ES906 ---
MESSERSCHMITT     Bf 109 G2 W.Nr 10639, RN228 ---
MESSERSCHMITT     Bf 109 G6 VX101 ---
MESSERSCHMITT     Bf 109 F2 W.Nr 7232, white 11 ---
MESSERSCHMITT     Bf 109 F4 Black 6 W. Nr 10639 ---
MESSERSCHMITT     Bf 109 G4 B ---
MESSERSCHMITT     Bf 109 G2 HS¡ ---
MESSERSCHMITT     Bf 109 F4 AX ? ---
MESSERSCHMITT     Bf 109 G4 AX JACK No. 1 Squadron SAAF ---
MESSERSCHMITT     Bf 109 F4 KJ ? ---
MESSERSCHMITT     Bf 110 AM30
MESSERSCHMITT     Bf 110 D AX772 --- jul-40
MESSERSCHMITT     Bf 110 D W Nr 4035 --- 1941
MESSERSCHMITT     Bf 110 G AM15 (W Nr 180560) 23 June 1945
MESSERSCHMITT     Bf 110 G-5/R1 W Nr 420031 (AM85) Flt. Edwards. 28-jul-45
MESSERSCHMITT     Me 163 B
MESSERSCHMITT     Me 262 B-1A/U1 W Nr 110305 --- May 18th, 1945
MESSERSCHMITT     Me 262 B-1A W Nr 110165 ---
MESSERSCHMITT     Me 262 B-1A  White 5 W Nr 111690 No. 417 Recovery and Salvage Unit (RSU)
MESSERSCHMITT     Me 262 A-2A "Black X" VP554 W Nr 500200
MESSERSCHMITT     Me 262 A-2A "Yellow 17" W Nr 500210 No. 616 Squadron RAF
MESSERSCHMITT    Me 262 B-1A  Yellow 5 W Nr 500443 ---
MESSERSCHMITT    Me 262 B-1a/U1 Red 12 W Nr 111980 ---
MESSERSCHMITT    Me 410 B-6 W Nr410208 AM74 --- 1945
MESSERSCHMITT    Me 410 A ago-43
MESSERSCHMITT   Me 410 A-3 W Nr 10259 F6+OK nov-43
MISTEL S3B (Ju 88H-1/Fw 190 A-8) Air Minister 75
MISTEL S3B (Ju 88H-1/Fw 190 A-8) Air Minister 77
RHOENBUSSARD Rhonbussard  26/10/1940
SIEBEL Si 204 D-1 WNr 322127 AM4  1945
SIEBEL Si 204 D-1 VN112
One of my colleagues built one of these.......
https://www.scalemates.com/topics/topic.php?id=11647
in RAF colours. From memory, aluminium dope with roundels and serials on fuselage, underwing serials only.
I think this was his main reference
https://www.prints-online.com/aviation-images/brunswick-zaunkoenig-xv190-parked-18413802.html
Hi Ed.
Thank you very much for your comments on this topic. We will probably go for the aluminium dope.
There is a second photo on that site which shows the roundels underwing.
https://www.prints-online.com/aviation-images/brunswick-lf-1-zaunkoenig-18400284.html
Does anyone know what this inscription reads?
Captura-de-pantalla-2024-02-26-211914.jp
Santiago
The LF kit gives RLM02 as the overall colour (standard Luftwaffe colour for trainers/prototypes I believe) and when tested by the RAE the German markings were painted over with a slightly darker grey.
https://www.scalemates.com/kits/lf-models-7243-th-braunschweig-lf-1-zaunkoenig--162272#
https://www.somanyaircraft.com/models/aips/patriot-200808-page4.pdf
I don't think it was finished in aluminium dope as there aren't any reflections or shiny parts to the finish. The inscription says 'Zaunkonig'.
Steve
Hi Steve,
Thank you very much for your post. I think that I will go for the RLM02 as the overall colour  with a slightly darker grey for the German markings.
Great. We will ask to our friend for that inscription in order to be able to do this model.
Santiago
Hi Steve
My father has finished the model. We will ask our friend Luis for the decal for the inscription that says 'Zaunkonig´in order to finish it.
Whats-App-Image-2024-02-29-at-17-32-42.j
Whats-App-Image-2024-02-29-at-20-17-29.j
It is a nice addition to our collection of captured German aircraft.
Santiago
