Mike Posted September 7, 2022 Share Posted September 7, 2022 A-1J Skyraider Update Sets (for Tamiya) 1:48 Eduard Another older kit from the Tamiya gets the modern Eduard treatment. The 1:48 Skyraider from Tamiya is another of their kits that were awesome when they were first released, and are still pretty good almost 25 years later. We’ve got new technologies to improve these kits with now, and Eduard are renowned for grabbing those technologies with both hands to improve our models. Eduard's new range of sets are here to improve on the kit detail in the usual modular manner. Get what you want for the areas you want to be more of a focal point. As usual with Eduard's Photo-Etch (PE), Löök and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between. The resin sets arrive in the new shallow Brassin cardboard box, with the resin parts safely cocooned in bags, and the instructions folded around acting as padding. Brassin Wheels (648761) Kit wheels are generally in two halves, which means you have the resultant joins to deal with, possible mould-slip issues on single part wheels, and sometimes less than stellar detail due to the moulding limitations of styrene injection technology, especially in the tread department. That's where replacement resin wheels come in, with their lack of seamline and superior detail making a compelling argument. They are also usually available at a reasonable price, and can be an easy introduction to aftermarket and resin handling, as they are usually a drop-in replacement. This set includes three resin wheels, a 3D printed tail-wheel strut and a sheet of pre-cut kabuki-style yellow masking tape that allows you to cut the demarcation between tyres and hubs sharply and with little effort. Once the parts have been liberated from their casting and printing bases, they are drop-in replacements for the kit parts, with massively improved detail, especially around the tyre sidewalls, tread detail, and the brake housings on the rear of the hubs. Each wheel also has an element of sag engineered into the tyre that is suitable to an operational aircraft, without looking like it’s got a slow puncture. The rear strut for the tail wheel is removed from its printing base with nippers, a sharp blade or saw, and provides exceptional detail over and above what’s possible with injection styrene. Löök Pre-Painted Resin Set (644165) This set contains a combination of pre-printed resin and PE parts to quickly and efficiently detail up your cockpit. There is a single resin part to replace the kit instrument panel in front of the pilot, with highly effective gloss varnish simulating the glass covering painted over the dials for you on black resin. Additionally, the PE set contains the four-point belts for the pilot, complete with pale grey comfort pads that protect the pilot from the buckles. Seatbelts STEEL (FE1291) These belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting. Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE. It includes a set of four-point belts for the pilot, complete with pale grey comfort pads that protect the pilot from the abrasion of the buckles during operations. You might have noticed they’re identical to the Löök set above, so bear that in mind if you’re planning on opening your wallet for multiple sets. Highly recommended. Review sample courtesy of Link to comment Share on other sites More sharing options...
