AJ/SK/SH-37 Viggen Control Surfaces (Q72355 for Tarangus)
1:72 CMK by Special Hobby
If you’ve got a Tarangus or Special Hobby Viggen in 1:72 and want to mobilise the flying surfaces to add a bit of visual interest, here’s the easy way to do it.  This set contains all four flying surfaces for the delta wings, which you’ll need to remove from the kit wings before replacing them with the resin parts.  Handily the starboard wings are marked with a double bar on the casting block, although that’s going to be thrown away before fitting, but common sense should carry you through along with the knowledge that the actuator fairings face down.
A simple set that will give your model a more candid look with minimal effort.
Highly recommended.
Review sample courtesy of
