Leopard C2 MEXAS Canadian MBT
1/35 HOBBYBOSS via Creative Models
In 1978 the Canadian Army selected the Leopard 1A3 to be its new Main Battle Tank. These would be called the Leopard C1 in service.  In 2000 it was decided to upgrade these tanks with the fitment of surplus German Leopard 1A5 turrets. At the same time armour protection was increased, and a new fire control system was added.  In 2006 some of these tanks were sent to Afghanistan where they would be fitted with an additional upgrade, the MEXAS system. This stands for Modular Expandable Armour System which was developed n=by IBD Deisenroth Engineering in Germany.  This is a new composite armour system which can be added to many vehicles include tanks to increase survivability in these modern conflicts where IEDs and RPGs feature heavily. The Canadians also fit a version to their LAVs.
The Kit
This kit from HobbyBoss is a re-boxing of the standard Leopard 1 with different parts for the Canadian MBT. Its worth noting the kit does not feature the thermal blanket and cooler fitted at a later date by the Canadians in Afghanistan. The kit looks good on the sprues with lots of detail parts. Moulding is first rate.
Construction starts lower hull. Various suspension components are fitted, and the ends of the main torsion bar system and its arms are fitted. The wheels can then be built up and attached, followed by the tracks which are individual links. While at first glance thy look good and there is a jig provided in the kit to make short runs of track however it will take some work to get them right; and the end connectors are moulded to the links so will not articulate like the real ones when the runs go round the end sprockets.
The next step is a surprising one in that it looks like a full power pack is provided. While the engine has many parts and looks quite detailed there is no detailing for the engine bay, and the actual block is missing all of its hoses and connector, though there is nothing stopping the modeller going to town here if they want to do an open engine bay. Then the rear bulkhead is made up. There is virtually no moulded on parts here with a lot of small detail parts making up this bulkhead. The rear mud flaps are fitted to the bulkhead at this point. The bulkhead can then be fitted. Moving to the top main hull the engine deck hatch is added, along with some side parts and the drivers vision blocks, the rear exhausts are then added along with quite a few detailed parts such as tools , mirrors etc.  The lower and upper hulls can now be joined and the rear bulkhead fitted. PE parts for the engine deck are then fitted. The additional MEXAS armour packs are added to the sides of the hull and the front.  The rear tow cables are then added.
Work now moves to the turret which has good casting detail moulded in. The mounting points for the MEXAS armour are all moulded to the turret. After the turret is together the large rear mounted turret storage bin is made up and added to the turret, Next up the roof mounted machine gun and its mount can be added. The ECM system and MEXAS armour units can then be assembled and added to the turret. Next up the hatches and aerial mounts are added.
The gun and its additional armoured mantlet are built up, There are two guns in the kit and the one with the mounting straps for the muzzle referent mirror on it. These are then added to the turret after it is assembled There is a canvas mantlet cover to add, this is a basic representative of the real thing and aftermarket detailed one are available to replace this one, in addition to would seem the Canadian's replaced the original covers with one of their own making. Like a lot of Leopard kits the kit barrel is not entirely accurate due to the complexities of the real thing and the limits of plastic moulding technology. The smoke dischargers are added to the turret and its then ready to be mounted to the hull
Decals
Decals are provided for 4 tanks in Afghanistan though there is no information on these provided at all in the instructions.
Conclusion
This is a great looking kit from HobbyBoss and their attention to detail is to be commended. Overall Highly recommended.
Review sample courtesy of
