Jul 7 2010, 07:16 PM
Post
#1
muhahahahahahahaha Group: Administrators Posts: 4,817 Joined: 23-March 07 From: SLAAAAGH Member No.: 3 |
The Hansa 581 is a double action, gravity fed airbrush from the German manufacturer Harder and Steenbeck. Specifically targeted at the entry level side of the market, the 581 has a 0.2mm needle, and a 2ml cup - it comes packaged in this compact little hinged case.
![]() Like the Evolution series, the Hansa shares a similar mechanism and components, visually the main body of the airbrush resembles the Evolution series. The Logos and individual manufacturing run number are laser etched onto the side of the brush. The small cup unscrews for ease of cleaning. ![]() ![]() The rear portion unscrews to reveal the needle and nut, its a little tricky to unscrew the trigger assembly and chuck from the airbrush body as the thin knurled edge leaves little for the fingers to grip onto compared to the rubber bands wrapped around the Evo, but after removing this the trigger assembly is the same simple to remove and clean design as the more expensive H&S brushes. ![]() Moving to the front of the brush the tip removes to reveal a more compact nozzle design than the other H&S brushes, a small rubber O-ring seals the nozzle to the airbrush body, the air-head unscrews from the tip for the benefit of cleaning (one piece on the Evo) and the needle slides very solidly into the nozzle assembly. ![]() So, how does it spray ? Very well is the answer, fine lines are very easy and for detail work this brush is easily as capable as much more expensive models,the trigger action is smooth, doesn't feel quite as smooth as the Evo but nevertheless reeks of quality and refinement. Cleanup is effortless and dare I say it slightly easier than the Evo, maybe it was me but the nozzle felt easier to clean up and the needle didn't drag as much paint out of the rear of the brush, I assume owing to a tighter seal between the cup and the trigger assembly. The 0.2 mm needle is good for detail, not so good for wide coverage so bear this in mind if you aim to paint larger scale models, however properly thinned the brush does an admirable job and airbrushing is more of a pleasure than a chore. The 2ml cup I'm not mad about, I don't really see the point of a small cup on an airbrush, but for detail work the 2ml cup does the job. Conclusion Retailing at under £100 the 581 is a beautifully crafted little airbrush that shares the same kind of performance with the more expensive models in the H&S line, with very few compromises in design. If I had to be picky I'd say its a little trickier to dismantle, and isn't quite as asthetically appearing as the Evo series, but the real test is how it performs as an airbrush which is passes with flying colours. Highly recommended. John Morrey Sample provided by Harder and Steenbeck |
Skii Hobbyline 581 Airbrush Jul 7 2010, 07:16 PM
Mike Nice one John - they certainly show their shared h... Jul 7 2010, 11:13 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd September 2010 - 04:38 AM |
