sandy Posted May 4, 2007 Share Posted May 4, 2007 Saw a very nice set of zotz decals for an F-14 so bought them and then started looking for a kit to go with them - got a nice deal on ebay for a tamiya F-14 1994 version with a technics cockpit but the only issue was is part done - got the model and the front end was complete with the cockpit installed and painted but was to a pretty good standard so i could live with it ( and it was to much hassle to try and break it up). Next job, put the rest together , sand it , fill it , sand it , fill it , and so on till I`m ready to put the first coat on - THEN IT GOES WRONG !!!! the previous owner had sprayed areas with an enamel primer and yep you guessed it soft boy here decided to use tamiya acrylics now have a paint job that any gardener would be proud of as a prime example of crazy paving ARRRRRRRRRGGGGGHHHHHH!!!! Well its back to sanding , filling , sanding , filling and a bottle a red wine !!!!!!!! Sandy Link to comment Share on other sites More sharing options...
Guest les Posted May 4, 2007 Share Posted May 4, 2007 Get some model strip from Hannants Modelstrip MODSTR01 £3.99 Modelstrip. Paint stripper for removing paint without damaging the model. 115ml (sufficient to strip approx 575cm2) Does not work on some cellulose, polyurethanes & factory finishes. Link to comment Share on other sites More sharing options...
neilfgr2 Posted May 4, 2007 Share Posted May 4, 2007 Mr Muscle oven cleaner does work.. does not attack the plastic.. Or, just do what i do... chuck it in the bin and go and watch some porn.. Cheers, Neil 2 Link to comment Share on other sites More sharing options...
Leigh Posted May 5, 2007 Share Posted May 5, 2007 Wierd, I use enamel (spray can) primers then acrylic paints all the time never had a problem. But then I NEVER use Tamiya acrylics. Link to comment Share on other sites More sharing options...
Mike Posted May 5, 2007 Share Posted May 5, 2007 I think you said it best - one of those days... Don't give up though, as there are ways of fixing the situation. I hate to see kits going in the bin Link to comment Share on other sites More sharing options...
