Michael Morris Posted February 7 Share Posted February 7 I'm making a small vignette of a 1/144 Learjet flying very high over the sea at night. My idea would be to have a base of a picture of the sea, with a layer of patchy cloud a couple of centimetres above it, then the plane mounted on a clear plastic rod about 5 cm above that. The scene will have a backdrop of the night sky on two sides, so this will provide some support for the cloud layer. So my question is this - How to make a thin layer of patchy cloud that is rigid, but looks sort of realistic? I was thinking about using furniture stuffing for the clouds and soak them in something to make them rigid. If so, what would I use? An alternative would be to make a thin, but very rigid, frame and attach the furniture stuffing to that. I could then mount the frame on the background. If I go for this option, what ideas do [people have for the best material and construction technique for making a frame that wouldn't sag? Thanks Link to comment Share on other sites More sharing options...
Michael Morris Posted February 7 Author Share Posted February 7 8 minutes ago, Black Knight said: At a fabric shop, get toy stuffing. There is another name but I've forgotten it. Its a loose fibre stuff. Although its 'loose' it can be formed and shaped and will hold the shape I used some of it in this for the 'smoke' and this, for the sand 'cloud' in front of the mine clearer Thanks. That's the stuff I was going to use. However, my question was about how to make a rigid layer of it. Link to comment Share on other sites More sharing options...
Solexman Posted February 7 Share Posted February 7 Why does it need to be rigid? Use the toy stuffing as above, form it into a layer, then support it on a fine wire armature which in turn is attached to your backdrop. If you wanted to firm it up I’d use cheap hairspray. Link to comment Share on other sites More sharing options...
