A6M2 Zero Control Surface Correction Set (4464 for Academy) 1:48
1:48 CMK by Special Hobby
Academy released their new tooling of the Japanese Zero in 2022 as a Battle of Midway 80th Anniversary boxing, but the model’s control surfaces suffer a little from an overly deep representation of the ribbing, and have fixed elevators and rudder panel that can’t be posed deflected.
This set arrives in Special Hobby’s yellow themed blister pack, with a header card and the instructions forming the slot-in back to the package, and holding the resin in place within the blister.  There are seven parts in grey resin, all of which have separate casting blocks that are joined to the parts at the pivot-point that will be less visible if any mistakes are made.  The elevators are drop-in replacements, but the elevators and rudder will require removal of the moulded-in flying surfaces from the kit parts before the new resin parts can be added.  The instructions advise sanding a V-shaped bevelled edge on the cut lines to allow the rounded leading-edges of the flying surfaces to nestle closely to the hinge-points, which shouldn’t be too difficult, as the surfaces are all moulded as separate halves.
A worthwhile upgrade to the realism of the model, doing away with the deep recesses in the kit flying services, which is particularly noticeable on the moulded-in rudder.
Highly recommended.
Review sample courtesy of
