Short Sunderland Mk.I/II "Flying Porcupine" (SH72438)
1:72 Special Hobby
The Sunderland was developed by Short Brothers to an RAF requirement R.2/33 for a long range general purpose flying boat. It is thought Shorts took their work on Imperial Flying Boats to design the Sunderland, however the RAF requirement was released before the Imperial Airways requirements, and Short's decided to pursue both at the same time.  The Sunderland would be a large four engined flying boat with both defensive and offensive armaments.  The large wings which would mount 4 Bristol Pegasus engine were able to hold 200 Gallons of fuel giving the aircraft a 14 hour range.  For defense initially four guns were mounted in a rear turret, two guns in the nose turret, and two guns on each beam.  Later a dorsal turret would be added. Offensive weapons were carried internally and winched out under the wings through doors in the aircrafts sides. Later aircraft would also gain 4 fixed forward firing machine guns.   German pilots nicknames the Sunderland the flying porcupine and there are numerous cases of Sunderland fighting off superior numbers off attacking aircraft.  Radar fitted to these flying boats enabled them to become accomplished submarine hunters.  Production shifted to the Mark III in December of 1941. This had a changed hull to improve seaworthiness.  With 461 built this was the most numerous mark.
The Kit
This is a new boxing of the Mark III based on Special Hobby's new tool Mark V from 2019, with new parts for earlier marks. The parts on the sprues enable different marks to be made. In addition for early aircraft this kit contains a small 3D printed set of prop control units as later marks had covers on these.  This is an impressive kit with good quality large mouldings and a full interior.  Construction starts in the cockpit. The instrument panel and pilots seats are built up onto the deck with the control columns being added. The cockpit bulkhead goes in and there is an additional seat to fit on the bulkhead. At the other side what appears to be the navigators position goes in. The lower deck under the cockpit then is assembled with its bunk areas for crew rest on those long flights.  The next stage is to build up the weapons carriers and the rails which winch them out under the wings. 8 bombs are provided. The top and main decks can then be joined and the weapons section added to the rear of this sub-assembly. To the front is added the mooring deck/access to the front turret with a realistic grating effect to the floor, Additional parts can now be added inside both main fuselage halves before you can think about closing them up around the main internal section. The modeler can have the weapons windows open or closed but this needs to be done now as they swing inwards. At the rear of the main cabin the gunners position and access to the top turret parts need then to be added. At the bow the anchor needs to go in. Only once all this is done can the fuselage be closed up.
The exterior now needs to be looked at, The main top insert for the turret goes in, then underneath the hull step part is added. Both of these being inserts to allow for the different marks to be kitted.  At the rear the vertical fin and separate rudder go on, then the tailplanes, here the moving surfaces are moulded in. The main wings go on next. These are conventional left/right upper/lower surfaces; again the moveable surfaces are moulded in. The wings have large tabs which slot into the fuselage which should help then fit on correctly and not droop over time. If you opted for the bombs slung out under the wings now is the time to add the racks there.
We are now on the finishing straight. Still on the main wing the four engines are assembled, each with its own resin exhaust. The two main wing floats then go on. Next up its the gun turrets. All these are fitted from the outside which is a great help when it comes to masking and painting them as separate items.  The front turret can be mounted slid back for mooring or in its forward position. The front boarding door can also be open as all the structure behind it is in place. The props and exhausts go on here.  The last step is to attach all of the external aerials. Given there are four on the top, eight on each side; and two on the wings it's probably better left until after painting! If wanted by the modeler then beaching gear is provided for the aircraft.
Clear Parts
These are of the same excellent quality as the other kit parts, and again it can be seen there are parts for other marks on the clear spure.
Markings
The decals are printed by Cartograf so that guarantees there will be no issues with them. A generous four aircraft can be modelled using the kit decals,
  • Mk.II W3983/RB-R, No.10 Sqn RAAF, Pembroke Wales, 1941. In 1943 this aircraft was damaged attacking a U-Boat and towed in Gibraltar for repairs. Extra Dark Sea Grey/Dark Slate Grey over Aluminum.
  • Mk.II W3981/ZM-W No.201 Sqn RAF, Pembroke Wales,1941. In Dec 1941 she was transferred to Alexandria for transport duties. Extra Dark Sea Grey/Dark Slate Grey over Sky Grey
  • Mk.II L2160/NM-X. No.230 Sqn RAF, Detached to Greece April 1941. Dark Earth/ Dark Green over Sky.
  • Mk.II T9114/E, No461 (RAAF) Sqn, Pembroke Wales 1943. Late Extra Dark Sea Grey/Dark Slate Grey over White High Demarcation Scheme.
Conclusion
This is great new tool of an important though often overlooked aircraft for the RAF. The kit is very detailed indie and out. Very highly recommended.
Review sample courtesy of
  • Like 10
  • Thanks 3
