Mike Posted February 22, 2021 Posted February 22, 2021 Masking Sheets 1mm Grid (A.MIG-8045) AMMO of Mig Jiménez If you’ve ever wished that you could get larger sizes and bigger areas of kabuki-style masking material, wider than 40mm that’s available on rolls, you’ve had your wish granted with the release of their masking sheet that we reviewed here. AMMO have now released this new set of five sheets with a 1mm grid printed on it in a clear foil bag with branding over-printed and a green label in the middle, with a stated size of 290 x 145mm per sheet written in yellow on the front. The bag is resealable, which will allow you to keep the dust out, and other than that there’s not an awful lot to say, other than to extoll the virtues of Kabuki tape, which is a paper-based washi tape that gets its name from Kabuki theatre, where it is presumably used on the paper puppets, characters and backdrops. It is a low tack tape that can last years in position on your model without leaving any residue (I’ve done this in the past), is flexible so that it can conform to curved surfaces well, and you can burnish it down to reduce the likelihood of paint creeping under the edge, although not squirting too much paint on a masked model is still the best way to avoid creep. The grid is very handy to check the size of shapes you’re planning on masking, and it also looks a bit cool in situ before you spray paint all over it. The grid is printed in ink of course, and may have a coat of clear varnish over it to protect the printing as it seems shinier thank the bare tape, but I felt it would be a wise decision to test whether the ink could be removed by solvents that are present in most of our paints. I first tried Isopropyl Alcohol (IPA or Isopropanol), and it slowly brought a little of the printing off, although it was more visible on the bud than the tape. The Liquid Reamer brought it off much quicker as expected, because it is a much “hotter” chemical. The take-away is not to blast too much paint on at once, and resist handling until the paint is actually dry to the touch. If you’re at the stage where there is a lot of IPA or cellulose thinners taking off the inked grid, you probably have much bigger problems than a bit of grey mixing with your paint! Having played around with it for a while, it might be wise to peel larger sheets of masking material off the backing paper before drawing out or transferring your design, applying it to a flat surface such as a mirror or a spare tile to finish preparation. Peeling the paper off a very complex design may cause a few more grey hairs as well as risking puckering the edges with the resultant stretching and potential lack of adhesion. Highly recommended. Review sample courtesy of 1
