While building my current 1/48 F4U with its 8 aftermarket resin rockets and in the process of folding 16 multiple bend tiny PE mounting brackets, I thought others may find it useful on how I go about it.
This is the starting point, in this case some Eduard PE.
Corsair_Construction_63
If I can build a quick and dirty jig to do the folding job I will. Definitely when there are multiples of the same - simplifies, speeds and ensures they're all the same.
So I knocked up this little jig from polysytrene by drilling a hole in some card and gluing in a post of the rocket diameter, glued a square shape equivalent to the top form of the bracket and a slot to take the PE piece.
Corsair_Construction_64
Load up your prepared strip.
Corsair_Construction_65
Using tweezers and a toothpick form your bracket.
Corsair_Construction_66
Corsair_Construction_67
And it's done. Quick and easy. Also less likely to spring off into the nether regions. Ready to adjust and glue in place.
Corsair_Construction_68
Let me know if you have other techniques.
Ray
Edited by Ray_W
Missing word
