I-16 Type 29
ICM 1:32
Design work on the I-16 began during the summer of 1932 at the Central Aero and Hydrodynamic Institute. When the tiny I-16 flew for the first time in December 1933, it was far ahead of any other fighter design in the world, featuring retractable landing gear, a cantilever wing and variable pitch propeller. Although not among the best remembered aircraft of the thirties, it was nevertheless a very able and rugged machine and featured prominently in the events of the time.
When the Spanish Civil War broke out, almost 500 were put into service with the Republicans. The outstanding manoeuvrability, firepower and rate of climb, surprised the enemy leading to the opposition nickname of Rata (Rat) and the friendly name Mosca (Fly). Equipped with the Soviet 20 mm cannon it was the most powerful aircraft weapon in front line service with any nation on the eve of World War II. It had a very high rate of fire and was extremely reliable. Another batch of I-16s was purchased by China to fight the Japanese, again surprising the other side with excellent performance.
When it first appeared, the I-16 Ishak (Little Donkey) was powered by a radial engine which developed a modest 450 hp. Even with this it achieved a creditable 376 km/h (234 mph) and, as the world's first single-seat fighter to have low monoplane wings, an enclosed cockpit (on some versions) and a retractable undercarriage. It was immediately put into mass production alongside the Polikarpov I-15 biplane fighter. Development led eventually to one version of the I-16 reaching over 520km/h (325 mph), with an engine of about two-and-a-half times the original power.
At this point the I-16 might well have faded into obscurity, if not for the outbreak of the Spanish Civil War in July 1936. This war drew support from all over the world. The Nationalists, supported mainly by German and Italian forces, were the better equipped. Britain, France, the United States, the Netherlands, Czechoslovakia and Turkey all sent an assortment of aircraft to the Republican forces, directly or indirectly. But by far the major supporter of the Republicans was the Soviet Union, which supplied 1,409 of the 1947 aircraft contributed by other countries. 475 of these aircraft were Polikarpov I-16s.
They first entered combat in Spain in November 1936. Flown in many cases by Soviet pilots, they proved more than a match for German He 51 fighters and Arado Ar68, but met their equals in the Italian C.R.32 biplanes and were overpowered by Messerschmitt Bf 109s. From March 1937, all remaining I-16s were concentrated into Fighter Group 31, and this was by far the most successful of all Soviet-equipped units.
Meanwhile, I-16s were fighting also in China, and in 1939 were operated against the Japanese in Mongolia. Their final fling came during the early part of the Second World War, but by then they were overshadowed by more advanced foreign types. Suffering the brunt of the German invasion, those remaining were replaced by more modern fighters in 1942-1943.
The Type 29 differed from the earlier Type 28 by having two synchronized ShKAS in the nose and a single 12.7 mm (0.50 in) UBS in the bottom of the fuselage; it had no guns in wings which were reserved for ground attack weapons. Three rocket racks were mounted in each wing. Additionally, starting in 1941, the external fuel tank hardpoint was changed so that it became multipurpose: it could carry the new type of drop tank, PLBG-100, or a FAB-100 bomb. Wartime photographs from the summer of 1941 show two configurations: one with 6 RS-82 rockets and two FAB-100 bombs and another with four RS-132 rockets
The Model
This is the third in ICM’s series of I-16’s, the previous releases being a Type 24 and a Type 28. As with the previous release there is a nice artist’s representation of the aircraft on the box top. Once you take the lid off the box and opened the inner lid, you will find four large sprues of grey styrene, one small clear sprue and a medium sized decal sheet. All the parts are superbly moulded, with no sign of flash or other imperfections and only a few noticeable moulding pips. There are a few swirl marks in the plastic, but nothing to worry about and will easily be covered when the kit is primed and painted. Since the aircraft was mostly wood there are very few panel lines, where fabric was used in the construction, the kit shows the underlying structure, but in a nicely restrained way. Is is interesting to note that this is not5 just a re-release of the Type 28 with added weapons. The wing sprue is completely new with the correct modifications/differences not only to the wings, but also the cowling front.
Construction begins with the wings and the two upper sections being attached to the single piece lower section, after which the port and starboard clear navigation lights are attached. Each aileron is moulded in top and bottom halves, which, once joined together are fitted in the desired poses, along with the lower underside of the nose.
The cockpit is assembled next, and is a very nicely detailed area. The rear bulkhead is fitted with the seat backrest and support, while the two piece rudder pedals are assembled.  The pedals are fitted to the cockpit floor, along with the rear mounted battery box. The front and rear bulkheads are then glued into the left hand fuselage section along with some sidewall detail. The floor is then slide in through the front bulkhead opening and glued to the rear bulkhead. The two piece throttle is assembled and glued into position, and then the instrument panel, which is moulded in clear plastic is fitted with the instrument decal. The rest of the cockpit is then detailed with the oxygen bottle instrument panel, joystick, a couple of handles, and seat. On the opposite side wall the undercarriage handle and a couple of instrument clusters are attached.
The firewall is fitted with the two piece oil tank and two gun troughs, before being fitted to one half of the fuselage. The two piece rudder and three piece elevators are then assembled, as is the two piece upper nose section. The fuselage halves are then joined, and the rudder, horizontal tailplanes and upper nose section attached, as are the two door panels.  The fuselage and wing assembly are then glued together.
The engine bearers and attached to the engine mounting ring, followed by gearbox case and intake manifold, the two halves that make up the cylinders, each with exquisite fin detail, are joined together, then fitted with the piston rods and individual exhaust pipes, before the gearbox assembly is fitted to the rear. The completed engine is then attached to the fuselage. The engine is cowled with three optionally fitted panels, plus the three piece nose cowl, with optionally positioned vents. The two machine guns fitted to the upper nose are then slid into their associated troughs, followed by the gunsight and windscreen.
The build is finished off with the assembly of the two main undercarriage units and the various weapons, including two piece drop tanks and two piece rockets on separate single piece rails.. Each undercarriage unit is made up of a two piece wheel, single piece main leg, complete with actuator, two outer doors, with separate hinged lower section, there is a second support rod fitted with another door which is glued to the leg and rear mounting point in the wing. The tail wheel is then attached, as is the tail cone and rear light, the drop tanks and rockets, side mounted venturi style pitot, aerial mast and what looks like an aerial unit, aft of the cockpit.
Decals
The decal sheet is printed by ICM themselves. The decals are quite glossy, well printed, in register and nicely opaque, particularly useful for the large white arrow. There are four decal options with this release, they are:-
  • I-16 Type 29, Red 75 of the 4th Guard Fighter Regiment of the Baltic Fleet Aviation, Winter – Spring 1942 in white over light blue camouflage
  • I-16 Type 29, White 12 of the 4th Guard Fighter Regiment of the Baltic Fleet Aviation, Winter – Spring 1943 in dark green over light blue camouflage.
  • I-16 Type 29, White 75 of the 71st Fighter Regiment, Autumn 1941 in dark green and black over light blue camouflage.
  • I-16 Type 29, White 13 of the 158th Fighter Regiment of the Northern Fleet Aviation, Pskov Region, July 1941 in dark green and black over light blue camouflage.
Conclusion
I really like the I-16, there’s something about the old I-16, no matter which type. Whether it’s the cute little plane, or the plucky little fighter going up against the odds, with only the skills of the Soviet pilots keeping the aircraft, which was quite difficult to fly and fight with, in the air. Even though it is really very nice and will build up into a great looking model there is plenty of provision for the super detailers amongst us to really go to town on the interior.
Review sample courtesy of
