AH-64D British Army - Update set, & Masks
1:72 Eduard for Academy Kit
These are sets for the new Academy kit.
Update Set (73641)
This set has one brass fret & one nickel one. The coloured parts are primarily for the cockpit in the form of new instrument panels and side panels, There is also a new MFDs, other cockpit parts, and seatbelts.  There are new parts for inspection panels, and grills. There are parts for the Hellfire missiles, their launchers and the CRV-7 rocket pods. The engine exhausts get new grills. For the canopy there are new cable cutters and wipers. For the ECM / Countermeasures system there are new parts and finally there are new parts for the rotor head.
Zoom Set (SS641)
This is just the colour fret from the update set.
Masks (CX522)
Supplied on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the glazing.  In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Tface Masks (CX523)
Supplied on yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the glazing (inside & out).  In addition you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Review samples courtesy of
