What is the quickest and easiest way in which to tidy up tyres. The tyres on my F1 Renault have a rather prominent seam all around the centre of the tread. As they are slicks, I suppose some form of sanding will do the trick, but is there any 'special' tips or tricks around this?
Karl.
Karl.
Well I suppose take it to about 12,000 rpm, then sideslip the clutch...
i can tell you how i do mine.
Make a mandril, i found that a 13 mm socket with a bolt through the middle with a nut to hold in place ,this can then be put in a cordless drill slide the tyres on the socket run drill sand tyres gives em that bin round the track look. good eh. :analintruder:
Edited by live steamer
Karl.
To get rid of the seam on rubber tyres, I generally use a fairly coarse grade of wet 'n dry on them, with plenty of water to stop the rubber 'picking up'. Usually works.
B)
