Mike Posted October 28, 2007 Posted October 28, 2007 Sometimes, when the clocks go forward or back, your time will be an hour out on the board, which can be checked at the bottom right of any page on the board. If you've not got the correct time, or it's out an hour after the change from/to Daylight saving, click on My Controls > Options > Board Settings. There you'll see a bunch of settings to let you change your time. The top box is your base timezone, which should auto-set correctly (should!). If it's not right choose the right one for you, and then choose underneath whether you use the Auto Correct DST function, which usually works for most people. If you're in the minority for which it doesn't work, untick Auto Correct DST, exposing the tickbox underneath, which allows you to manually set DST. You'll need to set this at every hour change each year. Once you're done, click Change My Account Options at the bottom to save the changes.
