Flybe E-195 airliner, pics from Antony Robertson
Flight deck
Front galley area
A view looking down the cabin from the front
Tops of the wings
Aft galley area
A shot showing the wing evacuation route marking, its not a great shot but gets the idea across
Right hand horizontal stabiliser and tail
Aft service door and aft baggage door
Aft fuselage with rear belly fairing showing #2 hydraulic system access panels and lots of dirty streaks under the windows
R/H main landing gear from the rear
View into the R/H gear bay
A side on view of the gear
Front view of the gear
A view of the R/H main landing gear doors showing their relative positions and paint demarkation
A view of the pylon flap fairing showing the oil staining
R/H winglet showing aft position lights and rear strobe light
Front of the R/H winglet with position light and front strobe
Outboard side of R/H pylon showing dirt and heat staining
Outboard side of right hand engine
  • Love 1
A view looking down the intake
Inboard side of right hand engine
Right hand forward belly panel with air-con pack access door and paint demarkation line
Close up of the front baggage door
Front service door
R/H fuselage above the nose landing gear showing the position of the RAT door in relation to the gear doors ( the outline of the closed front doors can just be seen
Nose landing gear
R/H nose showing the position of the sensors
Front left side a picture of the air data probes, tat sensor and ice detector:
Left side of the nose landing gear showing the steering motor
A slightly closer picture of the ground power socket and nose gear doors ( the front ones are closed on the ground )
Front passenger door with the ground power receptacle door underneath:
A view from the front showing the postion of the markings and the demarkation of the white and blue:
The left hand wing root showing the position of the landing and taxi light:
A view of the front left belly fairing showing an air-con pack access panel and the hot air outlet which is very nice on a winters day while changing the inboard wheel!:
A view looking aft at the undercarriage
A view looking into the gear bay, not a clean area!:
A side view of the gear taken from the gear bay:
A view up into the wing section of the gear bay showing mounting points, frames and pipework:
A view of the inboard side of the left hand engine:
Outboard side of the left hand engine:
Pylon behind the engine showing lots of dirt and heat staining on the metal areas:
Left hand winglet showing the position and forward strobe lights:
A view looking inboard along the trailing edge showing heavy oil staining on the pylon flap fairing
Apu exhaust and access panel
Hydraulic system 3 service panel and access to the horizontal stabiliser actuator and system 3 components
