Shar2 Posted July 22, 2017 Posted July 22, 2017 Gun Barrels & Pitot Probes 1:32 Master This month’s releases from Master Models include these two sets for 1:32 scale aircraft. [AM-32-095] – Designed to be used with the Special Hobby Tempest Mk.V they are a simple replacement for the kits barrels, these being with a full jacket. Since they are a direct replacement, the wings will not require drilling out. Instead a backing plate will need to be made, if there isn’t one in the kit, and the barrels glued to that, ensuring the inner and outer barrels are correctly orientated, as the outer barrel is longer than the inner. [AM-32-096] – Designed to be used with the Special Hobby Tempest Mk.II and the hopefully released Sea Fury, they are a simple replacement for the kits barrels, these being with the fully inserted, shorter barrelled type. As with the above set the barrels will need a backing plate and ensure the inner barrel is recessed further into the wing than the outer. The pitot probe needs a 1.2mm hole to be drilled out before the probe can be glued into place. Conclusion The Special Hobby Tempest series of releases are superb in their own right, but adding more detail can be just as enjoyable and these sets, as simple as they are will do just that. Review sample courtesy of Piotr at
