scorpion Posted August 3, 2012 Share Posted August 3, 2012 hi,just wondering if any one has this set as i just bought it on line and am wondering if its any good?.it contains a fouga magister,ourgan and an alpha jet..thanks Link to comment Share on other sites More sharing options...
Panoz Posted August 12, 2012 Share Posted August 12, 2012 It contains the decent but rather dated Heller kits of the Ouragan & Magister as well as the Airfix Alpha Jet. Now these kits are over 30 years old with raised panel lines, basic detail etc but they are basically accurate and easy to build. (Not that you have any better alternatives...unless you buy a Airfix Fouga from Ebay which I don't really think that it's any better.) Decals are standard Heller fare; work fine but they are usually off-register. Now I might be wrong but the set I saw here also came with a F-84G (again the OKish 70s kit). But that was years ago and the contents might have been changed. Link to comment Share on other sites More sharing options...
scorpion Posted August 12, 2012 Author Share Posted August 12, 2012 how does the alpha jet compare to the matchbox kit for general overall look as i was thinking of using the matchbox decals as masking for getting the demarcation straight [esp the lightning flash] and when the paint is dry,remove the decals and replace them with the hellar alpha jet decals.....oh about the set you saw that also contained the f-84g?....that was the heller pdf 40th annaversary set Link to comment Share on other sites More sharing options...
Panoz Posted August 12, 2012 Share Posted August 12, 2012 how does the alpha jet compare to the matchbox kit for general overall look as i was thinking of using the matchbox decals as masking for getting the demarcation straight [esp the lightning flash] and when the paint is dry,remove the decals and replace them with the hellar alpha jet decals..... The Matchbox kit is complete rubbish. It was based on the mock-up and was released before the real plane even flew, so it is basically a model of a model. I have built three of the the four available Alpha Jet kits; unfortunately the Airfix one (what you get these days from Heller) is not one of them, so I don't know how they compare shapewise. As far as your plan is concerned, I don't think you will be able to remove the thick Matchbox decals that easily... oh about the set you saw that also contained the f-84g?....that was the heller pdf 40th annaversary set. That figures. Link to comment Share on other sites More sharing options...
scorpion Posted August 12, 2012 Author Share Posted August 12, 2012 no worries,would the decal idea work the other way around [using the hellar decals as the mask?] Link to comment Share on other sites More sharing options...
Panoz Posted August 12, 2012 Share Posted August 12, 2012 no worries,would the decal idea work the other way around [using the hellar decals as the mask?] Probably would... Never tried something similar but they are much thinner than the Matchbox ones. Link to comment Share on other sites More sharing options...
scorpion Posted August 12, 2012 Author Share Posted August 12, 2012 grand.i will try it that way,thanks Link to comment Share on other sites More sharing options...
scorpion Posted August 14, 2012 Author Share Posted August 14, 2012 this arrived in the post today and well pleased with it,im actually delighted that the alpha jet is moulded in white plastic so that will save a bit of time when it comes to painting it as the white parts are allready white [i absolutley HATE working with white paint]...oh and to correct myself ...its the 35th annaversary set [1953-1988],not the "30th" annaversary set which i originaly said it was Link to comment Share on other sites More sharing options...
