GCN butchers a P47 : TERMINATED.
gcn
It wouldn't be a SEAC Gb without a jug, nice one. is it 1:32?
I see on Rich's thread that you are going to use alclad for the first time.
Dont be scared of it, i have found that it is the easiest finish to spray.
As for the sanding, unless you are spraying chrome or a very high gloss finish, it is no different than spraying acrylic.
couple of questions
sorry about the size. The instructions show that the panel just behind the cowling is split into two but i'm not sure thats correct. Oh thats not my P47 BTW
secondly applying an oil based was over alcad is that likely to dull the finish, I know it does when applying it over a futured coat
Edited by gcn
ok progress pics.
Engine knackered replacement coming from a star in the US.
Cockpit done, Fuselage slapped together sanding almost complete. Hope to have the black primer on this weekend. THe sub assemblies can then be done while I wait for a delivery of Alcad
Cockpit painted with tamiya acrylics and washed with N&W oils and dry brushed silver and grey
Thanks guys
Managed to pick up white aluminium and dark aluminium from my LHS they didn't have normal aluminium but I have seen a number of jugs painted in white aluminium with various panels darkened so thats what i'll do.
Had a test run with the alcad on some sub assemblies last night and it went on a breeze. I primed with Tamiya gloss black, polished it up and then sprayed on the alcad straight from the bottle at about 13psi no problems at all.
I hope to have it all sprayed and decals on this weekend and with any luck piccies too.
Just need to wait for the engine bits to arrive and I can have my second attempt at producing a good wiring job that will almost totally be hidden away once complete. :rolleyes:
I dont know sorry, never done it.
Managed to get the painting done whilst using up about £75 worth of Tamiya masking tape.
Alcad was good although I must de-tack the tape a bit next time as it left some marks that were stubborn to move. I used White aluminium for the majority and highlighted with Duraluminium
Used IPA to thin my Xtracrylix which I preferred over water although the tape lifted up some of the OD. Guess Alcad isn't a great key for it. Blue is Tamiya XF-8, might be a touch light IMO
Decals next but I'm not sure what an oil wash will do to the alcad though
Edited by gcn
  • 4 weeks later...
Nice work GCN :thumbsup: think it's fair to say you've nailed the Alclad, looks damn nice. Looking forward to seeing it finnished. Cheers. jim :D
Unfortunately Jim you won't.
I ended up with far too many silly mistakes and errors for my liking so Teddy got slung from its pram and its in the bin.
I'd lost some motivation but its back now. I'm going to have another go with a new one and try and get it right this time
Sorry to hear about your loss
Gone to heaven ... :angel:
Edited by Erwin
There will be a speedy reincarnation though.
I'm debating whether to buy the Hasagawa one to swipe the decals only and build up the Tamiya one - expensive option
or just buy the Hasagawa one.
Can't find any suitable decals unless you know different
