tomprobert
Aircraft in Miniature 1/72nd scale Boeing 747-300 KLM
Looking absolutley brilliant Tom. Flawless workmanship, I've thoroughly enjoyed watching this,
John
[Edit] What are you going to build next ? Is there a 1/72 A340-600 ? :thumbsup: [/edit]
Edited by Viking
John
Many thanks John.
I wouldn't go quite as far as 'flawless', but nevertheless I'm pretty pleased so far.
As for a 1/72 A340... well that would be lovely! There isn't one available yet, but you never know. I have a DC-10 on my 'to do' list though, so I may take the plunge and do a British Caledonian one.
But then I also quite like the idea of a 767 too, and a DC-8, and the A310 is also nice...
One... must... control... ones... self! :D
No... you... mustn't!
I've been working on getting the gear bays completed this week before I begin installing the landing gear properly.
I used this picture of the bays to guide me on the internal colouring:
http://www.airliners.net/photo/Cathay-Paci...F%29/2026634/M/
As you can see they are a sand colour in this photo, so that's the route I've gone down. I have seen other pictures where the bays are grey, but I think this adds a splash of colour to an otherwise fairly drab underside.
First up was masking the bay areas:
Then the bays themselves were sprayed using Humbrol sand:
I've also scratch-built the doors using plastic card and Evergreen strip. Here is the fuselage gear doors in the process of being painted:
And here are the finished doors ready for installation when needed:
The exterior of the doors are Dove Grey.
Now I can progress with getting the landing gear installed... I'll keep you posted.
Tom
Edited by tomprobert
you missed some detail on the inside of the doors........
go on chris....have a go.....
I've never built a vac form before Kev and this is way out of my league
Edited by cuprar
dont look that hard to build you should be able to do it
If you've never tackled a vac before, my advise is to steer well clear of a kit such as this... it'll put you off for life!
Cut your teeth on a Welsh Models kit... they are the best vacforms I've ever built. When you've got a few 'under your belt', then give something like this a go.
Just my :2c:
Tell me more...
More progress on the undercarriage...
The nose wheel has been done. The etched brass that comes from the kit was easy to use and fitted really well. It definately enhances the look of the metal leg. Here is the nose gear with the wheels being test fitted:
The main gear has lots of wiring etc, so these were used to represent this - Little Cars 0.2mm black wire and some old electrical cable:
The etched brass retraction gear on the body undercarriage had some Evergreen strip added to reduce the 2D effect:
Here are the body legs and struts in place before painting and addition of the pipe work:
Some piping and outboard doors added:
All doors attached:
And finally, a test fit of the wheels:
Next job will be the wing gear.
Tom
Just my :2c:
Tell me more...
Yes done loads of vacform kits and got many more to do will be getting one of these tho I like the challenge
A man after my own heart... :)
i took one look at it and thought NO WAY!!!!
It does at first but after I downloaded the instructions from there site it's not to bad and seeing this being done gives me the more feeling that I could do it and make a nice kit of it
...I could do it and make a nice kit of it
The trick with something like this is to concentrate on it and it only.
By all means take a break from it if you need to, but otherwise, dont get distracted and start doing other kits - just stick to one and above all,
take your time!!!
I've known Tom for years and he's always been a very talented guy, but for me to do something like this would mean doing it over a lot longer period, I couldnt do it as quick as he has.
btw Tom - gear door detail....go check out as many close ups of 747 gears as you can find; there is a wealth of things to add....the average jet aircraft has awesomely complex gear and gear bays.....so I'm not letting you off the hook with this beauty
:devil:
:wicked:
tom - re the gear details....
you said; "tell me more"
ok....
hope these help....and I expect to see all the wires, cables, jungle etc......
by expo....
I'm always amazed at what a complex structure the average jet gear is....
ok....
by expo....
Brilliant Kev, thank you. Also very useful for the weathering under there!
I've got the majority of the landing gear done now, just a few more pipes to add here and there.
Here are the main undercarriage units at the start of the process, with the wheels being test fitted to make sure everything sat level:
Here the legs have been cut to the correct height, and some initial pipe work added (I presume they are some form of break lines and hydraulics):
These few show the legs and wheels painted and in situ:
I've also started to do a little weathering and add some grime to represent that seen on an inservice aircraft:
I've still got to add the brake equaliser pipework and add some more weathering. I'll add more pictures when this is complete.
Nearly there!
Super job Tom.
You have done a great job to get all of the wheels making contact with the tarmac, and the detail you have added really makes the whole thing look superb
Chris.
