Antoine Posted December 22, 2007 Share Posted December 22, 2007 (edited) Starting this one today. Don't know if I'd be able to do a real step by step post, but we'll see. - Tamiya 1/48 spit I - Model Alliance 1/48 decal sheet PR Spits part I, ref 48131 - Airwaves 1/48 conversion fro Spit PRIc Type 2, ref 48038 Edited March 3, 2008 by Antoine Link to comment Share on other sites More sharing options...
rdxtnt Posted December 22, 2007 Share Posted December 22, 2007 Go for it Antoine. We know you can Link to comment Share on other sites More sharing options...
Antoine Posted December 22, 2007 Author Share Posted December 22, 2007 (edited) Go for it Antoine. We know you can Are you really THAT sure??? Edited December 22, 2007 by Antoine Link to comment Share on other sites More sharing options...
David_in_Fremont Posted December 22, 2007 Share Posted December 22, 2007 If that one goes together as nicely as the Mk.Vb from Tamiya you're in for a very enjoyable build! My one suggestion is to glue the upper wing surfaces to the fuselage first and then add the bottom. Like I didn't. Have fun! Link to comment Share on other sites More sharing options...
Antoine Posted December 22, 2007 Author Share Posted December 22, 2007 (edited) If that one goes together as nicely as the Mk.Vb from Tamiya you're in for a very enjoyable build! My one suggestion is to glue the upper wing surfaces to the fuselage first and then add the bottom. Like I didn't. Have fun! I didn't too! Too late. STAND BY Edited July 25, 2008 by Antoine Link to comment Share on other sites More sharing options...
Antoine Posted March 27, 2009 Author Share Posted March 27, 2009 I've decided to get rid of two/three half-build kit that are waiting in their boxes. Here is where I restart: Link to comment Share on other sites More sharing options...
Antoine Posted March 28, 2009 Author Share Posted March 28, 2009 I'm working on small parts, that will beglued latter, after painting. The screw, finished and varnished. Propeller tips are yellow, RLM04 to keep things easy. Blade are black Hub alu. the spinner is PRU pink. My "recette" is 5 drop of flat white tamiya (Much easier to use than gunze's), and a touch of red. DIfficult to see with the light... The undercart. Link to comment Share on other sites More sharing options...
Antoine Posted March 30, 2009 Author Share Posted March 30, 2009 Some difficulties with the PR canopy. Not that easy to cut.... I've butchered it a little... Masking. You really need a new cutter blade. The aft part, masked and in place. And the front... I've glued one side after the other. There are still some huge gaps, but I'll rework it once everything is dry, with some little putty rolls. Let's hope it'll work... Link to comment Share on other sites More sharing options...
Gary C Posted March 30, 2009 Share Posted March 30, 2009 Considering thats a vac canopy I'd say it's not a bad fit, just needs a bit of milliput. Watching with interest. Link to comment Share on other sites More sharing options...
Antoine Posted March 30, 2009 Author Share Posted March 30, 2009 Hi Gary, First time I use a vac canopy. It's true that it looks nearly ok (!) on the pic, and I'm nearly surprised, as I've seen it nearly all the afternoon long with my magnifying glass in front of the eyes! And then, it has an ugly look, with great big gaps. The putty is on, let's see tomorrow if I get some honourable result. Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 As there is to my knowledge no ready to use PRU pink available on the market, I did my own mixture, using tam XF2 flat white (9/10), and gunze H19 (1/10), straight on the airbrush. Does it seems PRU pink enough to your eyes? Link to comment Share on other sites More sharing options...
Tony Whittingham Posted July 22, 2009 Share Posted July 22, 2009 Hello Antoine, I was given a recipe for PR pink sometime in March/April. I will see if I can find the post Link to comment Share on other sites More sharing options...
Nick Belbin Posted July 22, 2009 Share Posted July 22, 2009 Could be wrong – but does it need the gunsight mount? Link to comment Share on other sites More sharing options...
Test Graham Posted July 22, 2009 Share Posted July 22, 2009 The monitor may be exaggerating, but possibly too pink. You want an off-white. Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 Could be wrong – but does it need the gunsight mount? Ahem.... Should be under the masking tape... At least I hope... Or did I slaughter it some months ago? I may have sacrified it to the carpet monster, too... Even if I have no carpet. Well, I truly don't know, we'll see tonight, when I take the tape off. Link to comment Share on other sites More sharing options...
Tony Whittingham Posted July 22, 2009 Share Posted July 22, 2009 Hello Antoine,I was given a recipe for PR pink sometime in March/April. I will see if I can find the post Found It. The recipe is 1/4 roundel red to 3/4 white, plus a touch of light gray to tone it down. ( thank again to Christian) Link to comment Share on other sites More sharing options...
Doug Rogers Posted July 22, 2009 Share Posted July 22, 2009 Nice to see one of the rarer Spitfire variants Antoine, looking forward to the result. Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 Found It.The recipe is 1/4 roundel red to 3/4 white, plus a touch of light gray to tone it down. ( thank again to Christian) Are you really sure? 1/4 roundel red should give something too much pink, I think. I thought the PRU pink was nearly white. Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 The monitor may be exaggerating, but possibly too pink. You want an off-white. The pic was taken in late afternoon, just before a storm, and without much daylight, only interior light. The kit is much clearer in good daylight. Link to comment Share on other sites More sharing options...
Seahawk Posted July 22, 2009 Share Posted July 22, 2009 Starting this one today. By the way, if you subsequently get tempted into doing that rather fetching Spitfire R7335 of 718 Sq, FAA, pse note that the code should read G3K on both sides, G3*K on the RHS and almost certainly G*3K (not K*G3) on the LHS. FAA codes comprise 3 elements and almost invariably read in the same order on both sides, as opposed to RAF codes where there can be discretion about how the 2-element squadron code and the individual a/c code are displayed (eg AA*B, B*AA, *AA-. Same mistake made in the instructions to the Seafire (is it 06B?) in the Airfix 1/72 FAA special issue. set. Nick Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 By the way, if you subsequently get tempted into doing that rather fetching Spitfire R7335 of 718 Sq, FAA, pse note that the code should read G3K on both sides, G3*K on the RHS and almost certainly G*3K (not K*G3) on the LHS. FAA codes comprise 3 elements and almost invariably read in the same order on both sides, as opposed to RAF codes where there can be discretion about how the 2-element squadron code and the individual a/c code are displayed (eg AA*B, B*AA, *AA-. Same mistake made in the instructions to the Seafire (is it 06B?) in the Airfix 1/72 FAA special issue. set. Nick Note taken, as I plan to build more PR spits. But as far as I know, there are no conversion at the moment for a XIII. Link to comment Share on other sites More sharing options...
Antoine Posted July 22, 2009 Author Share Posted July 22, 2009 Well, after a coat of klir, the masking tape is off, and the overall look is not too bad in the end. But.... The canon's battery are down! So, more pics tomorrow. Link to comment Share on other sites More sharing options...
ollieholmes Posted July 23, 2009 Share Posted July 23, 2009 Im looking forward to seing more progress on this one. I would like to build some of the PR Spitfires but the Airwaves conversions seem hard to get hold of. Link to comment Share on other sites More sharing options...
Antoine Posted July 23, 2009 Author Share Posted July 23, 2009 I still have those for the PRIV, PR1G, and PR1F, I'd get them from hannants. Link to comment Share on other sites More sharing options...
Antoine Posted July 23, 2009 Author Share Posted July 23, 2009 The mask on the canopy is off. I was afraid to discover the result, as I thought the mask has been damaged during the putty/sanding session. But in the end, it looks quite fine. I must admit that the result is not really to notch, but still, bearing in mind that its a rhodoïd canopy, I'm pleased with it I'll maybe try to cure the seam between the windshield and the fuselage with some basic masking, and then putty/sanding again, but I'm afraid to get a worst result. Link to comment Share on other sites More sharing options...
