self made filler using liqui poly and off cuts
phat trev
I have mixed some home made filler using humbrol liquid glue and sprue off cuts to fill some small surface gaps in a wing.
how long does a small application of this take to cure before can start sanding down the area?
cheers
Depends on the mixture & how thick it was applied. Last time I did this it was 2 days before I could work on it properly - I overfilled slightly & used the tip of a craft knife on the overfilled area to gauge how hard/set it was.
it is quite thick (close to marmite viscosity) well its been 6 hours now since i applyed the mixture and after proding the area with a blade (good advise) the surface has not hardened yet, think I will wait until the morning.
thanks for the advise.
cheers
In my experience, a couple of days at least or expect it to tear out when you sand it.
