Fifer54 Posted September 15, 2011 Share Posted September 15, 2011 I'm having a silly problem with KLEAR. On my Revell F-4C Phantom that I'm building for the Phantom STGB, I have an assortment of different paint finishes. It's on SEA camo, and the Tan has dried Matt, the Dk. Green is also Matt, but the Lt. Green has dried with a satin finish, as has the Camoflage Gray on the underside. That's OK, I thought, a good coat of KLEAR will sort that out and "homogenise" the surface finish with a nice gloss. Erm, no! I apply my KLEAR with a nice soft flat brush in flowing strokes over the model, and i've found that over the matt areas, the KLEAR has flowed out and given me a super satiny-gloss surface, but on the satin areas, the KLEAR just will not flow, and pools on the surface, with its surface tension "pulling" it into the pools. Has anyone come across this before, and what did you do about it? I think that the solution may be to thin the KLEAR slightly, but what should I use as a thinner? Has anyone any ideas? Link to comment Share on other sites More sharing options...
cheeley Posted September 16, 2011 Share Posted September 16, 2011 but what should I use as a thinner? Don't know if it will help, but I've heard IPA can be used to thin / clean up Klear. Also as ammonia can strip Klear, so something with ammonia in it; like some window cleaning products might do The trick. Link to comment Share on other sites More sharing options...
Rob P Posted September 16, 2011 Share Posted September 16, 2011 A quick rub over the satin areas with the finest grade of wet and dry would probably do the trick. It will rough the surface up just enough to provide a key for the clear. Link to comment Share on other sites More sharing options...
zero Posted September 16, 2011 Share Posted September 16, 2011 (edited) sorry, double post Edited September 16, 2011 by zero Link to comment Share on other sites More sharing options...
zero Posted September 16, 2011 Share Posted September 16, 2011 (edited) Agree, Rough the surface a little with a light sanding and then clean the dust with wet/damp kitchen roll, it will look a mess but once the Klear is on this will bring out the shine. give it a couple of coats and on the last one you can add some flat matt to the clear to pull down the shine to a satin or matt finish all over (test your mix on a scrap bit of paint) but about 5% flat matt I find works great for modern jets, 25 to 30% for WWII stuff 5% just looses that overall high gloss shine you get from klear (if you want to lose it) ie no flat matt applied About 30% applied to klear Has anyone come across this before, and what did you do about it? I think that the solution may be to thin the KLEAR slightly, but what should I useas a thinner? Has anyone any ideas? Klear doesn't need thinning even through a airbrush, just mist it on with a airbrush, or use a wide brush. it thin enough as is so just use out of the bottle. hope this helps Dave Edited September 16, 2011 by zero Link to comment Share on other sites More sharing options...
Fifer54 Posted September 16, 2011 Author Share Posted September 16, 2011 Thanks, gents, I'd not considered treating the surface to make it suitable for Klear, only treating the Klear to make it suitable for the surface! Link to comment Share on other sites More sharing options...
