New Klear and Vallejo Medium/Fix
kruncher
Just a word of warning to the wise.
I have used the new version of Johnsons Klear (Multi-surface Wax) with the Vallejo decal medium and fix.
The results are not very promising.
The new Klear seemed to go on with no problems and seems quite fine after a couple of brushed on coats.
This was left a few weeks whilst on Holiday.
I downloaded an instruction set for the Vallejo fluids and used them as instructed.
The tamiya decals are quite thick , as i'm sure most of you will know and so I used a fair bit of the Medium to soften the decal.
However the overwash has reacted badly with the Klear and I'm not sure if I can save this situation. :(
I tested the fix solution as well after what I found and this reacted also!
This was my fault as I should have tried a test piece before committing. But be warned.
