jaw Posted August 15, 2011 Share Posted August 15, 2011 Good afternoon BMers, I'd welcome some advice please. I have just purchased the Welsh Models 1:144 kit of the Andover C1. A rather nice little kit with a vacform fuselage and im wings/tailplane. But of course it comes with RNZAF decals and I want to do the RAF version in the dark earth/tan/black scheme. I have managed to get some pics of Andovers in flight but what I would like to know is whether these aircraft had underwing serials on both wings or just on one, and whether they had underwing roundels - again on both sides or just one? I have also seen that they had the light aircraft grey scheme all over with 32 Sqdn, and red/white/LAG with 115 Sqdn and raspberry ripple with the ETPS aircraft. Choices, choices, choices but I think I will stick with the desert scheme - at least for the moment! Thanks, John Link to comment Share on other sites More sharing options...
Max Headroom Posted August 15, 2011 Share Posted August 15, 2011 You could also so the prototype G-ARRV being one of the two original Avro 748 prototypes...... http://m.photobucket.com/image/G-ARRV/Amos...pg.html?src=www Trevor Link to comment Share on other sites More sharing options...
Vulcanicity Posted August 15, 2011 Share Posted August 15, 2011 http://www.airliners.net/photo/UK---Air/Ha...ee3441775f3b4e9 http://www.airliners.net/photo/UK---Air/Ha...ee3441775f3b4e9 The above two photos appear to suggest that neither side had underwing serials/roundels in the Black/Dark Earth/Mid Stone scheme. Also bear in mind that there are two versions: the Andover C.1/E.3 (which your kit presumably represents) has a longer rear fuselage and clamshell doors, giving quite a different shape to the CC.2, which as a VIP machine was more like the civil HS.748 in shape. At least some of the 32 squadron aircraft in the grey scheme were the CC.2 version Hope this helps! Link to comment Share on other sites More sharing options...
Mr T Posted August 15, 2011 Share Posted August 15, 2011 The colours used for the intila RAF scheme were Dark Earth and Light Stione with Black undersides. The upper colours are available from Xtracolour. So far as I can remember they carried medium sea grey underwing (?) serials under one wing (starboard) and a red/blue roundel under the same wing. The serial read from the roundel inward, thus O XS608. Of course at some stage they may have carried serials under both wings. Hope this helps and that someone else can confirm or correct as necessary I have not got access to the info at the minute . At some stage at least one Andover was painted in the Dark Green, Dark Seay Grey Light Airvraft Grey sceme. Link to comment Share on other sites More sharing options...
David Womby Posted August 15, 2011 Share Posted August 15, 2011 >> what I would like to know is whether these aircraft had underwing serials on both wings or just on one, and whether they had underwing roundels - again on both sides or just one? > > Definitely can see the underwing roundel (red/blue only) and serial on starboard wing of this shot and I think there's a serial under the port wing too: and a serial for sure on port wing of these: I think they may at one time have been roundels on port upper and starboard lower only but somebody more knowledgable than I am is bound to know. David David Link to comment Share on other sites More sharing options...
Evalman Posted August 15, 2011 Share Posted August 15, 2011 I have also seen that they had the light aircraft grey scheme all over with 32 Sqdn, and red/white/LAG with 115 Sqdn and raspberry ripple with the ETPS aircraft. Choices, choices, choices but I think I will stick with the desert scheme - at least for the moment!Thanks, John Another couple of choices, some nice anniversary schemes. I'm not sure if decals are available. 60 Squadron: 115 Squadron: Link to comment Share on other sites More sharing options...
Dave Fleming Posted August 15, 2011 Share Posted August 15, 2011 (edited) . At some stage at least one Andover was painted in the Dark Green, Dark Seay Grey Light Airvraft Grey sceme. XS644, with 46 Squadron and 51 Squadron (For testing ELINT gear) - it had serials and red/blue underwing roundels The RAF had a VIP configured C1 in white/grey with a very thick blue flash (XS637), and 60 Squadron latterly had the same C1 in a 75th anniversary scheme The overall light grey ones were, I suspect, Medium Sea Grey over Light aircraft grey (in line with other RAF transports, the division between the colours was very hidden - look at the lower nacelle) - It could have been Barley/Camouflage grey on the uppers instead. There are also the RAE and ETPS aircraft, initially in a few schemes then in Raspberry Ripple, the open skies aircraft in white/grey - and the prototype painted up as a Russian aircraft for the film Invasion in 1980!! Lots of nice pics here: http://forums.airshows.co.uk/viewtopic.php?f=40&t=29115 Hadn't realised the Welsh kit was out - been waiting 25 years for that one! Edited August 15, 2011 by Dave Fleming Link to comment Share on other sites More sharing options...
jaw Posted August 15, 2011 Author Share Posted August 15, 2011 Thanks chaps, Your info was most helpul. John Link to comment Share on other sites More sharing options...
Homebee Posted August 16, 2011 Share Posted August 16, 2011 A grey one V.P. Link to comment Share on other sites More sharing options...
Tartan11 Posted September 18, 2012 Share Posted September 18, 2012 (edited) Bearing in mind that the Andover C1s were delivered to the RAF over 40 years ago --- From memory the original colour scheme of dark earth/mid stone/black I THINK had white underwing serials both sides. I can't remember if there was a roundel under one wing or both. Note that I am refering to the factory applied colours here - obviously changes were made in service. If there had been a kit available at the time I would have taken more interest ! Edited September 20, 2012 by Tartan11 Link to comment Share on other sites More sharing options...
