RAF Squadron Serials WW2
Deacon
I am trying to find out if there was a convention regarding the RAF squadron serial codes of WW2.
I've just completed a Spitfire Mk.II, and with the nose pointing to the left I have put the codes QV (under the canopy) then the roundel, then J.
But, how should it read the opposite side?
Sorry if this is a lame question, but I have a Mk.IX which shows the serials as (pointing left) ZX (under canopy) roundel 6, (pointing right) 6 roundel XZ under canopy.
Finally I have a Mk.I which (pointing left) ZP (under canopy) roundel J, (pointing right) ZP roundel J under canopy.
Deacon
The instructions could be interpreted to suit the airframe; they just said that the two-letter Squadron code had to be on one side of the roundel, with the aircraft's individual letter on the other side.
Edgar
Basically all squadron codes on all types had the unit code ZX, QV etc forward of the roundel BOTH sides as standard. So, for example, your ZX-6 is right! One or two squadrons did this differently. 65 squadron for example always had their code 'SH' forward of the roundel on the port side and on the starboard, reading from the right(Nose of aircraft) aft of the roundel so on the left side the read SH*B and on the right hand side SH*B as opposed to other units that would have read WZ*B and B*WZ.
Basically the unit two letter code generally always under and slightly behind the cockpit.
Hope this helps.
Edited by Paul J
Well, I'm afraid what you said is wrong, both generally, and specifically. There was no 'standard' way of applying the code. As regards Spitfires at least, some units applied the squadron code (Deacon, note that the two-letter unit designator is known as 'code' not 'serial'; 'serial' is the specific airframe number) near the cockpit on both sides and the aircraft letter near the tail, others had the opposite arrangement (squadron code near the tail and aircraft letter near the cockpit); while others applied the letters in XX*A arrangement on both sides, where XX is the squadron code. 145 Sqn/Polish Combat Team was in the latter category (at least in early 1943), so your ZX-6 is wrong, as the code should read ZX-6 on both sides (meaning that on the starboard/right hand side of the fuselage the ZX was near the tail and the 6 was under the cockpit).
By the way you put it it sounds the same as what I have stated but another way!!!!!! You need to re -read it and you'll see that I am right. As usual there were several anomalies and it was the exception rather than the rules!!!!!! The codes were applied at Squadron level and other units in addition to 65 may have positioned their code at the rear on the starboard sidebut in all cases the roundel positionwas always symetrical on both sides.
Edited by Paul J
.. in all cases the roundel positionwas always symetrical on both sides.
Not sure that that's true either. ISTR that the factories applied Lancaster fuselage roundels in staggered positions to permit application of the codes in the XXoA arrangement on both sides. Or were you just talking about Spitfires?
Edgar
As Edgar says. Different squadrons did it in different ways. It wouldn't surprise me if there were occasional inconsistencies even within the same squadron.
Deacon, were you using my decal set for your Mk II? If so, I would advise having the squadron codes forward of the roundel on both sides, as this appears to be normal practice for 19 Squadron.
Regards
Stewart
P.S. If you want to do a 1:72 Spitfire II Long Range, I've just released the parts and decals.
Edited by 3DStewart
Photos in Polish Wings 13 show ZX-0 and ZX-5 that way on the starboard side, and Wojtek Matusiak states that this is because it was standard practice to have them that way on 145 Sq. It may well be ideal to want a photo of ZX-6 as well, but I think I'm pretty safe in thinking it will be consistent rather than an oddball.
Fair dos. Humble pie taken BUT as mentioned earlier application of codes are subject to variation at the whim of units and exceptions to the rule. Maybe I didn't explain myself too clearly but I hope the gist of it was understood and am mainly talking about fighter aircraft.
Hi
To quote an exception to all the rules
I have a photo (packed away) of a lysander coded PV-P, all ahead of the roundel on the port side, it is an ASR lysander,but it has a yelow/black under engine cowling a target tug.( presumably a replacement part)
Jerry
Hi
3-letter groups also seen on Mustangs, Spits, Mossies, Beaufighters ....
The only conclusion to be drawn from this thread is that if you only have a reference for one side of an aircraft - you cannot be sure what is on the other! Although you can sometimes make an educated guess, depending on what other refs you have.
CT
One needs to remember the way in which code letters developed. At first the idea was to have the Squadron number, in the colour of the relevant flight (as in the 19 Squadron photos,) but this was discarded in favour of letters, and the reference was clearly designed for bombers, since it has 48" as a general height, which would never fit onto fighters.
This reduced to 36", which was fine (just) for Hurricanes, but hopeless for Spitfires (DW-K anyone?)
It was reduced to 24", as a general rule for fighters, but this was still a struggle for Spitfires, since there is not 24" to spare under the glass, with the canopy open, so Spitfire Squadrons received a special dispensation to use 21" letters. This worked fine, and, of course, made it easier to fit the Squadron letters aft of the starboard roundel, even though it meant painting over the serial no. (which mattered little, since it was still whole on the port side.)
Difficulties recommenced when the roundel was moved forward, very late, or post, war, possibly due to the arrival of the cut-down fuselage, and there is a very clear photo of Mark 21s, of 41 Squadron (port side only) with the "E" of the Squadron code obscured by the open door.
Edgar
Found pictures in my various refs and there does seem to be a number of variations and mostly down to squadron level. A Polish squadron for example had the 'WX' AFT of the roundels by the tail on BOTH sides! Many units had the codes Forward of the roundels both sides just behind the cockpit as did many units have them fore and aft of the roundels i.e reading left to right YY * Y on left and right sides. So there are very many variations to the 'exception rather than the rule' scenario.
CT
Hi Chris,
I forgot those aircraft....
Your post reminds me it is time to browse your excellent 2nd TAF books again, I just realised it is about a year since I last picked one off the bookshelf....
Are there any new books by you in the pipeline that you are able to reveal ?
Jerry
Hi Jerry
Glad you like them and that they are on your shelves and not in store! Nothing in the immediate pipeline I'm afraid. Concentrating on getting my records in order ... you'll know what I mean ... and wondering which model to build first. Or which of half a dozen to finish.
Chris
