At Sea Posted June 26, 2011 Share Posted June 26, 2011 Hi, I have come back to modelling after many years away and have found so much pleasure in this, however this time around the research is as much fun a the build. The first kit I attempted a couple of years ago was a Trumpeter Lightning F Mk 3 which I built 'out of the box' but it was missing the paint chart. I made it up using the box top art work and now it looks so wrong it makes me itch. Dark sea grey over light aircraft grey with early 60's decals. Could anyone please inform me of the best way to remove humbrol enamel (2 coats of brush painted grey and one of satin laquer) from this kit so I can start again using the modeldecal sheet I have bought for this aircraft (1960's all metal 19 squadron RAFG). Thanks and sorry if this is posted in the wrong area. Cheers. :-) Link to comment Share on other sites More sharing options...
Sivcev Posted June 26, 2011 Share Posted June 26, 2011 (edited) I am using this Edited June 26, 2011 by Sivcev Link to comment Share on other sites More sharing options...
delta7 Posted June 26, 2011 Share Posted June 26, 2011 I have used modelstrip to take enamal off a 1/48 spitfire and repaint - it worked well http://www.wonderlandmodels.com/brands/modelstrip/ I painted it on and put the kit into one of those bags you get with oven cleaners, left it overnight and scrubbed off the paint with a toothbrush - it didnt harm any of the clear parts hope this helps Link to comment Share on other sites More sharing options...
Dave Gibson Posted June 26, 2011 Share Posted June 26, 2011 Could anyone please inform me of the best way to remove humbrol enamel (2 coats of brush painted grey and one of satin laquer) from this kit so I can start again using the modeldecal sheet I have bought for this aircraft (1960's all metal 19 squadron RAFG). The best I've come across is drain cleaner. Get it from your supermarket or hardware store. If they have the gel type, it's even better, because it sticks to the plastic. Wear plastic gloves and specs. It should strip in half an hour. Dave. Link to comment Share on other sites More sharing options...
Harry Lime Posted June 26, 2011 Share Posted June 26, 2011 I use the well known product illustrated in the first post. Works every time on the Humbrol and Xtracolour enamels I use. Link to comment Share on other sites More sharing options...
spike7451 Posted June 26, 2011 Share Posted June 26, 2011 I've tried brake fluid in the past which worked ok but took a long time to do it's job.. Link to comment Share on other sites More sharing options...
c.smith10 Posted June 26, 2011 Share Posted June 26, 2011 awsome stuff Link to comment Share on other sites More sharing options...
At Sea Posted June 26, 2011 Author Share Posted June 26, 2011 Thanks every one for your help. I have bought some model-strip as suggested in the 2nd post and will try it, I'll post the results up when I get home on leave and give it a go! Link to comment Share on other sites More sharing options...
At Sea Posted July 24, 2011 Author Share Posted July 24, 2011 Thanks every one for your help.I have bought some model-strip as suggested in the 2nd post and will try it, I'll post the results up when I get home on leave and give it a go! It works incredibly well! Used it and have now stripped another Lightning. Also I was amazed at how good the aerosol Humbrol Metal Cote aluminuim is. Pics up soon, once I get me, a camera and my models together! Thanks, as always for the advice. Link to comment Share on other sites More sharing options...
Uncle Uncool Posted July 24, 2011 Share Posted July 24, 2011 Uh-huh... 'N' nay forget 'bout the suggested music for the task; 'Paint Removal M'chine,' by The Cult. Cheers there, Unc² Link to comment Share on other sites More sharing options...
Vulcanicity Posted July 24, 2011 Share Posted July 24, 2011 If the methods suggested above don't work, you could try Tesco's Value All Purpose Cleaner. It costs about 30p a bottle (literally), and is a good deal less nasty than brake fluid/oven cleaner. It even has a fresh fake lemony smell! I managed to strip very thick 8-year old Humbrol paint (enamel and acryllic) off a Vulcan with it, so it should work wonders on a recently-painted Lightning. Link to comment Share on other sites More sharing options...
Blacktjet Posted July 30, 2011 Share Posted July 30, 2011 (1960's all metal 19 squadron RAFG). Just thought I'd point out ( so you don't waste all that time and effort removing the paint only to make another error), 19 squadron didn't fly the F.3, no RAFG squadron did. They only had the F.2, F.2a and T.4 Link to comment Share on other sites More sharing options...
