hawker typhoon progress
A few pics to show the progress of my Typhoon.
Unfortunatly, because it builds so quickly (it's the academy 1/72 Typhoon Mk.IB) I have no progress shots of the model up until the main parts had been glued together.
The Cockpit is the one given with the model and I think it looks good enough, when the painting is complete I am going to scratch build the gunsight support and gunsight.
Hmm, I have some Airfix Tempest tailplanes to use (airbrush testing fodder) ...but will stick to the smaller ones as I cannot be bothered to chop around at the tail to get a good fit.
Well it's primed with a humbrol white spray can as I can decide to give it D-Day stripes or not tomorrow.
Never done this before so a first for me (and its with an airbrush) :shocked:
Edited by phat trev
Oops :( it was going so well too. Mask the black, spray some white, call it pre-shading ;)
Was looking at the same kit in my LMS today and was tempted after seeing your build but the new Airfix Seafire XVII won instead. Maybe next payday.
I wouldn't call the stripes a fail
Truly, you should see some of the real striping underwing that I found when researching my Tiffie
That model is looking very good, far better raw material than the elderly Frog kit I resurrected too. Keep on so I can enjoy it, nice to see another Tiffie in progress
And the black and white stripes, not exclusively D-Day markings. They were applied to the Typhoon much earlier in the war so that the Tiffs weren't mistaken for FW190s by ground based Ack-ack and also for airborne recognition, so pretty well a vital part of the Tiffie's colour scheme from soon after entering service.
A little touching in with a fine brush and that's your Uncle Bob :thumbsup2:
I like the structural detail in the wheel wells of the moulding. It took me ages to replicate that
As you can guess, you just won a happy lurker
bill
The Academy is a really is a good model, a bit of TLC and I hope it will look the dogs inbetweens.
I have managed to wipe the offending black stripes (if you can call them that) off using meths (works really well as long as the surface below is cured well -it was-)
Another quick coat of white and this time I have masked off the white areas only followed by a coat of Xtracrylix Medium Sea Grey which is quite dark so I added a little white.
Thanks for the chin up Purdu. In view of the stripes I was thinking of doing the early 'friendly fire' id markings but found all the photos of typhoons that wore them were car door versions.
Edited by phat trev
I realise about the early type having the recognition marks ( I have a spare home moulded car door canopy if you want it, could even do you one with the "mirror dome" upper bulge too if you like :) ) but this shows how the markings got worked over in service, looks like the Typhoon in this picture has parts of the skinning from several aircraft
