madaboutmodels Posted June 2, 2011 Share Posted June 2, 2011 (edited) . Edited July 27, 2012 by madaboutmodels Link to comment Share on other sites More sharing options...
madaboutmodels Posted July 3, 2011 Author Share Posted July 3, 2011 (edited) . Edited July 27, 2012 by madaboutmodels Link to comment Share on other sites More sharing options...
David Womby Posted July 3, 2011 Share Posted July 3, 2011 Cute and looks really good in that colour scheme. David Link to comment Share on other sites More sharing options...
Viking Posted July 3, 2011 Share Posted July 3, 2011 Nice looking model , I reckon that it is at its best in the BA scheme. You going to build a fourth, in what scheme? John Link to comment Share on other sites More sharing options...
Antony Robertson Posted July 3, 2011 Share Posted July 3, 2011 Very nice. Antony Link to comment Share on other sites More sharing options...
madaboutmodels Posted July 3, 2011 Author Share Posted July 3, 2011 im thinking of doing a forth in cityjet Link to comment Share on other sites More sharing options...
madaboutmodels Posted July 8, 2011 Author Share Posted July 8, 2011 to start with i wanted to do it as BA Connect, but i could find the decals and i think this is better Link to comment Share on other sites More sharing options...
Rabspat Posted July 9, 2011 Share Posted July 9, 2011 Looking at this on my blackberry at the hospital. From what i can see it looks good matey, the only thing that i think you need to do is use masking tape for the blue as it does look a little messy. Other than that i love it but then i am a BA fan. Link to comment Share on other sites More sharing options...
madaboutmodels Posted July 9, 2011 Author Share Posted July 9, 2011 i do use masking tape, but it lifts and rips the paint when i lift it, im currently after some tamiya tape Link to comment Share on other sites More sharing options...
Rabspat Posted July 9, 2011 Share Posted July 9, 2011 i do use masking tape, but it lifts and rips the paint when i lift it, im currently after some tamiya tape Use ebay you can get good deals on it like 2 rolls for £5 etc. I use 10mm and 6mm, 18 mm is good for large areas. Link to comment Share on other sites More sharing options...
ryoga Posted July 9, 2011 Share Posted July 9, 2011 Hi Madaboutmodels It looks like you use a brush to apply paint on your kits. If that is the case, if you brush too hard over the masked areas, the paint will seep through as the brush push aside the taped edges. Try painting on the masked area towards where you want the paint to go. Just my 2 cents Link to comment Share on other sites More sharing options...
richellis Posted July 9, 2011 Share Posted July 9, 2011 also make sure you wash you model before you paint, and I sand it lightly, prime then mask to colour. If the model isnt clean the paint can lift when you pull the tape off. Also when you de-mask pull it slowly and back on its self. Link to comment Share on other sites More sharing options...
Kev1n Posted July 9, 2011 Share Posted July 9, 2011 another thing to try - spray your models using Halfords - they have most colours, including white and a close match to BA's blue... once you start this you will also discover the delights of masking.... with this particular model it can be a bit tricky but it's worth it first spray it completely with halfords primer, comes in white or grey then mask the lower part where the blue goes, spray the white let it dry for a couple of days.... this helps the paint dry properly and will help with the paint lifting off problem then mask off all the white parts using tamiya tape for the line between the blue and and the white and you can use more or less anything for masking the rest, I use the clear wrapping that magazines come in, cut to the shape I want (have a look at my topic on the Continental Boeing 777 - there's a pic of this) Then you can spray the blue it does take practice and dont hold the can too close, coz halfords paint comes gushing out so it's a quick 'swoooosh' across the model it's worth the hassle of masking, re-masking etc tho. Link to comment Share on other sites More sharing options...
madaboutmodels Posted July 11, 2011 Author Share Posted July 11, 2011 i'll try halfords paint, i do have an airbrush, but cant get the paint right. Link to comment Share on other sites More sharing options...
Kev1n Posted July 11, 2011 Share Posted July 11, 2011 takes practice, like most things but... practice doesnt make perfect; practice makes permanent. which means if you practice something wrong often enough, you'll be permanently wrong. Loads of people on this site will help with airbrush probs or any other prob for that matter so dont be shy, just ask ...and the only silly question is the one that doesnt get asked so ask anything anytime - somebody will know the answer Link to comment Share on other sites More sharing options...
