worm Posted May 30, 2011 Share Posted May 30, 2011 (edited) Made a start on my first 1/32 Revell Hawk today, I've decided to do this one as the 63 Squadron camouflaged machine, XX287. As you see in the photo I've also got three of the Xtradecal sheets and two Matra rocket pods from the 1/32 Revell Hawker Hunter kit which means I've got some pylons to build too, may have a go at making a CBLS, Carrier bomb light stores as well. The kit itself seems to go together fairly quickly as I managed to get quite a few of the subassemblies together today, photos will follow. Edited May 30, 2011 by worm Link to comment Share on other sites More sharing options...
worm Posted May 31, 2011 Author Share Posted May 31, 2011 (edited) Well heres some photos of what I've done so far. As you can see I've got the main cockpit tub parts together as well as the intake ducts and the exhaust, at the back of the last two items I've cut away the lip so I can fit the fan parts after painting. I've also drilled out the wing pylon hole as I'll use them for my scratch pylons. Today I got started on the weapons, using the Revell Hunter Matra pod, I glued it together and then cut off the tail cone and opened out the hole. The next thing to do is drill 18 holes in a disc of plastic for the rear of the barrel part. I also got started on the CBLS, again using part of the Matra pod, filling it with Miliput after gluing it together, when dry I'll sand down the rear part for the nose cone of the bomb carrier with the main body made from plastic tube and card. I also got a strt on the 190gal tanks for my Eagle armed Hawk but thats a seperate build. Edited May 31, 2011 by worm Link to comment Share on other sites More sharing options...
worm Posted May 31, 2011 Author Share Posted May 31, 2011 A friend has just emailed me about a firm doing resin pylons so it looks like I don't need to make my own. http://www.britmodeller.com/forums/index.php?showtopic=67949 Link to comment Share on other sites More sharing options...
worm Posted June 2, 2011 Author Share Posted June 2, 2011 Spent 4hrs today making the CBLS and its only half built but it does look good so far even if I do say so myself, should get it finished tomorrow and I'll post some pictures, then its into the rubber it goes. I love the smell of RTV in the mornings. Link to comment Share on other sites More sharing options...
Shaun Posted June 2, 2011 Share Posted June 2, 2011 Spent 4hrs today making the CBLS and its only half built but it does look good so far even if I do say so myself, should get it finished tomorrow and I'll post some pictures, then its into the rubber it goes. I love the smell of RTV in the mornings. Are there any chance of a copy if they turn out nice? Shaun. Link to comment Share on other sites More sharing options...
worm Posted June 3, 2011 Author Share Posted June 3, 2011 Yes there is Link to comment Share on other sites More sharing options...
worm Posted June 7, 2011 Author Share Posted June 7, 2011 Well, its getting there, slowly, could of made 5 of these for the parts I've cocked-up. Link to comment Share on other sites More sharing options...
Shaun Posted June 7, 2011 Share Posted June 7, 2011 (edited) Nice work on the CBLS, coming on nicely. Are you making 3Kg bombs to go in the pod? Have you done any more on the main airframe? Shaun. Edited June 7, 2011 by Shaun Link to comment Share on other sites More sharing options...
worm Posted June 7, 2011 Author Share Posted June 7, 2011 (edited) Hi Shaun Yes I'm doing the 3kg practice bomb but no further on the Hawk yet other that the conversion on the Hunter 230gl tanks to 190gl Hawk type. Steve Edited June 7, 2011 by worm Link to comment Share on other sites More sharing options...
Mark M Posted June 9, 2011 Share Posted June 9, 2011 id be interested in some resin aswell Link to comment Share on other sites More sharing options...
Shaun Posted June 12, 2011 Share Posted June 12, 2011 There maybe a little market for those CBLS pods with the 1/32nd Harrier GR7 out now and the future1/32nd Jaguar release. Shaun. Link to comment Share on other sites More sharing options...
worm Posted June 12, 2011 Author Share Posted June 12, 2011 Some more shots of the CBLS, nearly there. Link to comment Share on other sites More sharing options...
Mark M Posted June 15, 2011 Share Posted June 15, 2011 they look nice Link to comment Share on other sites More sharing options...
Royster Posted June 15, 2011 Share Posted June 15, 2011 That looks indepth! Nice work Link to comment Share on other sites More sharing options...
IV(AC)Plumb Posted June 15, 2011 Share Posted June 15, 2011 Are you aware there are some holes in the side of the outer case to fit the ERU carts and a cocking handle? http://photobucket.com/images/CBLS+200/ Link to comment Share on other sites More sharing options...
worm Posted June 16, 2011 Author Share Posted June 16, 2011 (edited) Hi I was leaving the holes till last just in case I cocked it up big time but thanks for the photo, very usefully. All the best Steve Edited June 16, 2011 by worm Link to comment Share on other sites More sharing options...
