Muzz Posted May 19, 2011 Share Posted May 19, 2011 I tried spraying Citadel paints today (Chainmail silver) can't remember if I've sprayed them before or not by tried to thin with Mr Color thinners which appeared to make it thicker. Then tried Tamiya thinners which worked better, when I went to clean the airbrush out I used some water which got rid of the paint no probes, so is water the best thinner for Citadel? Link to comment Share on other sites More sharing options...
jacksdad Posted May 19, 2011 Share Posted May 19, 2011 Aye. Link to comment Share on other sites More sharing options...
Muzz Posted May 19, 2011 Author Share Posted May 19, 2011 Cheers, I'll being using water in future then. Link to comment Share on other sites More sharing options...
Jon Kunac-Tabinor Posted May 19, 2011 Share Posted May 19, 2011 hi- if you thin with some tamiya thinner first you can them add isoprop alchohol too. if you add the alcohol first its too hot and the paint goes gloopy. weird but true. Cheers jonners Link to comment Share on other sites More sharing options...
Paul A H Posted May 19, 2011 Share Posted May 19, 2011 I usuall thin them with Tamiya thinner. They definitely don't mix with cellulose thinner, unfortunately. Link to comment Share on other sites More sharing options...
Pielstick Posted May 23, 2011 Share Posted May 23, 2011 Vallejo Airbrush Cleaner is pretty good for thinning Citadel paints (and also Vallejo, Xtracrylix and Lifecolor). Link to comment Share on other sites More sharing options...
Chewie Posted May 27, 2011 Share Posted May 27, 2011 Tap water or demineralised water. Personally, I use demineralised water to thin, and tap water to clean. Same goes for LifeColor. FYI, LifeColor and Citadel can be mixed safely too. Link to comment Share on other sites More sharing options...
