Started this today:
With a few extra goodies - Aires Cockpit set
And Aires Electronics bay
The first job was to scribe around the panel for the electronics bay, then gradually cut through the plastic (which is very thick - approx 1.2mm). I then fitted the electronics bay, which worked better with a small plasticard shim, but it still looks quite neat.
Then sanded down the cockpit floor and sides and checked the fit using blu-tac and tape
However I needed to sand more off one side for the nose gear bay to fit. However once that was done it fits reasonably well
Finally on with some painting - first sprayed the cockpit Aircraft Grey (or XF20 Medium Grey in tamiya), and an oil wash to pick out some of the details.
Then started painting the panels - still quite a lot of work to do on this, but it's coming along...
Peter
Looking good, I've had the same project semi started for some time now. The detail on the resin is just amazing.
I keep dry fitting and fettling the cockpit and nosewheel bays, but I'm still not happy with the fit. Glad to see it does all go together though :thumbsup2:
Any thoughts on markings?
Steve.
Today's work, mainly finishing up the cockpit
Then buttoned up the fuselage, and put the nose wheel bay in. Managed to get a glue fingerprint on the nose bay, but I can sort that out later
Peter
Oh watchin this one got it in the stash & the Aires pit + eduard exterior etch, nice to see now major probs with the fit of the pit.
Andy :speak_cool:
Today's work - first up sanded back the filler, then building up the PE for the HUD with the two acetate sheets.
Then fitted the resin parts to the front canopy, masked off the canopy with Parafilm
Then masked off the rear canopy
Made up the Engine pods, and filled and rescribed
Then started making some FOD covers - i'm not sure if i'll use them, but it's easier to make them before I fit the engines
Peter
Today's work on the Hog
First trimmed off the FOD Guards
Then sprayed them with Semi Gloss Black
Fitted the engines to the fuselage, and filled and rescribed - just a small plastic card shim and some Mr Surfacer
Then fitted the tail surfaces, once again just a little Mr Surfacer on some of the joints
Built up and fitted the wings, once again some Mr Surfacer on the wing roots
Finally sprayed the white in the wheel wells, and masked off the electronics bay
Peter
The last couple of days work:
Primed:
Then fitted the pylons:
Masked off the engine fans
Pre-shaded
Light Green (H303 Gunze)
Then Dark Green (H302 Gunze)
Then the Dark Grey (H301 Gunze)
Then finally a coat of Klear to seal it all
Peter
