Mike Posted May 14, 2011 Share Posted May 14, 2011 Railings - 2 chain bars 1:350 Eduard (99018) This set needs very little in the way of description. It is a sheet of railings with the 4mm vertical posts spaced every 5mm, and two chains between the posts, sagged slightly to give a more realistic look. There is also a bottom bar running along the full length to give the modeller a larger gluing surface. Each run is a shade over 13cm, and you get 11 runs, so you get approximately 145cm of railings on this 14cm x 7cm Photo-Etched (PE) fret. Great for adding realism to your 1:350 ship kits that don't have railings included in the box. Conclusion If your ship doesn't have chain railings included in the box, what could be better than this set? Review sample courtesy of Link to comment Share on other sites More sharing options...
warreni Posted June 7, 2011 Share Posted June 7, 2011 Two sets?? Link to comment Share on other sites More sharing options...
