Paul-H Posted May 1, 2011 Share Posted May 1, 2011 Hi Guys Looking for some advice of the correct colours to use on my RAF models I use Humbrol, Revell and vellejo so what are the recomended colours to use on a RAF model For Green and Brown top surface a blue underside and Grey and green to serface and Grey? underside I normally take the chickens route and use whats recomended in the instruction but suspect thats not the best option So what do you recomend This is what I have got from their verious instructions Revell Dark Green 68 Dark Earth 82 Sky 59 Greyish Blue 79 Medium grey 43 Greenish Grey 67 Humbrol Dark Green 116 Dark Earth 29 Aircraft Blue 65 Medium Sea Grey 165 Ocean Grey 106 Vallejo Dark Earth 029 Dark green 012 Sky 009 Ocean Grey 048 Medium Sea Grey 050 Thanks guys Paul Link to comment Share on other sites More sharing options...
dfqweofekwpeweiop4 Posted May 1, 2011 Share Posted May 1, 2011 You can get Vallejo model air paint sets for WW2 RAF planes. Should have all the main colours in there. You can get a paint set with 16 paints in it. That should suit most of your needs. thanks Mike Link to comment Share on other sites More sharing options...
Jennings Heilig Posted May 1, 2011 Share Posted May 1, 2011 Green and Brown top surface a blue underside Sky was the underside color. The official color wasn't blue, it was greyish green Link to comment Share on other sites More sharing options...
Test Graham Posted May 1, 2011 Share Posted May 1, 2011 From 1939 the main scheme was the Temperate Land Scheme : Dark Green and Dark Earth with various undersides, from mid 1940 fighters used Sky, bombers had black initially but Day bombers went to Sky. Fighters later adopted the Day Fighter Scheme: Dark Green and Ocean Grey with Medium Sea Grey undersides Maritime types used the Temperate Sea Scheme, Dark Slate Grey and Extra Dark Sea Grey initially the Fleet Air Arm used Sky Grey undersides, but Sky from September 1940. Maritime Patrol types changed to white undersides and sides with (eventually) only Extra Dark Sea Grey tops The Desert Scheme was Dark Earth and Mid Stone over Azure Blue The Far East used the Temperate Land Scheme with Sky Blue undersides, later Medium Sea Grey Later in the war the US scheme of Olive Drab over Neutral Gray (or a lighter grey) became common on US aircraft such as transports, light, medium and heavy bombers PR aircraft mainly used PRU Blue There were other schemes, and other details particularly PR and underside colours, but those were by far the most common. To check which commercial paints give the best matches look to websites such as IPMS Stockholm. Alternatively just buy the more dedicated model paints such as Xtracolour and White Ensign rather than those from the more generic companies. Link to comment Share on other sites More sharing options...
pte1643 Posted May 1, 2011 Share Posted May 1, 2011 VallejoDark Earth 029 Dark green 012 Sky 009 Ocean Grey 048 Medium Sea Grey 050 I can't comment on Humbrol or Revell, I use Tamiya and Vallejo pretty much exclusively. 029 Dark Earth is certainly in the Ball Park, but I found 012 Dark Green to be a little too "Grey"... I ended up with Tamiya XF-81 (RAF D. Green). The colour conversion charts show XF-81 as FS34079 which in turn equates to Vallejo Air 016 US Dark Green... Which is also a colour match for Humbrol 116 apparently. Link to comment Share on other sites More sharing options...
Ratch Posted May 1, 2011 Share Posted May 1, 2011 Humbrol 29 Matt Dark Earth & Hu: 116 Matt US Dark Green, camouflage 23 Matt Duck Egg Blue 106 Matt Ocean Grey & Hu: 116 Matt US Dark Green 147 Matt Light Grey Vallejo 009 Duck Egg Green, undersurfaces 016 US Dark Green & 029 Dark Earth 051 Barley Grey for undersurfaces 052 German Grey & 016 US Dark Green for upper camouflage 1 Link to comment Share on other sites More sharing options...
spitfire Posted May 1, 2011 Share Posted May 1, 2011 Have a look here, it's easy http://ipmsstockholm.org/colorcharts/stuff...orcharts_uk.htm Cheers Den Link to comment Share on other sites More sharing options...
Paul-H Posted May 3, 2011 Author Share Posted May 3, 2011 Thanks for the help guys, all sorted forn now, I hope Paul Link to comment Share on other sites More sharing options...
Roland Pulfrew Posted May 3, 2011 Share Posted May 3, 2011 There is a useful colour reference at this website Link to comment Share on other sites More sharing options...
