Kallisti Posted April 25, 2011 Share Posted April 25, 2011 So here is the box and sprue shots: As you can see from the labels, it was going cheap in the sale at ModelZone earlier in the year so I couldn't resist it. Its a big box and the sprues are also appropriately big! The plastic is the usual Revell silvery-grey, but I've already given them a coat of primer in these shots There is also a sheet of "gold" leaf to coat the lower part of the lander and a strip of clear acetate to make the windows, but I didn't include these in the shots. Link to comment Share on other sites More sharing options...
Graham77 Posted April 26, 2011 Share Posted April 26, 2011 Welcome to the build, for nearly 2 years I have been trying to build the revell saturn V which has a 1/96th version of this as part of the kit. I,ll not only watch with interest but may use your build to help finish a part if mine Happy Modelling Graham Link to comment Share on other sites More sharing options...
Obi-Jiff Kenobi Posted April 26, 2011 Share Posted April 26, 2011 Watching this one with interest I have one in the stash. Link to comment Share on other sites More sharing options...
Kallisti Posted April 27, 2011 Author Share Posted April 27, 2011 (edited) So having primed some parts and begun looking at assembly I realise that this is a quite poor kit! For a start fit looks terrible: Next looking at the docking ring on the top, there are huge pin marks, which sadly I forgot to photograph before sanding down, but amazingly enough you can see them in one of the assembled pics on the side of the box! Anyway, the docking ring on the model is nothing more than a cylindrical hole in the top do the ascent stage. WRONG! So I'm building this up from modelling clay to approximately the right shape: There are two astronauts, one with a backpack for EVA and one without for the inside of the module. Neither go together well and a lot of sanding along the joints are required Next I'll be reshaping the outside of the ascent stage as well as starting on the inside. I've decided that a small white LED will be enough to illuminate the interior so to power this I'll be inserting a 6v battery pack into the descent stage, opening a hole in the base of the ascent stage to pass wires up into the cockpit. I'll also arrange some sort of releasable hinge for the underside of the descent stage to allow access to the battery pack. All that is work in progress... Edited April 27, 2011 by Kallisti Link to comment Share on other sites More sharing options...
Mike Posted April 27, 2011 Share Posted April 27, 2011 Very interesting - I've got one of these myself Link to comment Share on other sites More sharing options...
