Sign in to follow this
tim dix
Blue Hawk XX231
Hi
For my next trick, I will be doing XX231, In a sassy little blue number. Cant work out how to do a link, but believe me, its cool.
Anywho, I will have to do it with a combination of decal sheets, as the original one from this box is missing, doh! I think I have all I need, except the white arrow for underneath, its exactly the same as the reds one, so I dont suppose anyone out there in Britland has a spare arrow from the original decal sheet, from this kit that they could let me have, id be very gratefull?
Hope your builds are going well
Tim
OK, so tonights efforts have been a little slow, but im quite pleased with them.
I sprayed the 2 sprues with primer, then set out painting the tub and control panels. I decided the ones in the kit are just a bit rubbish, so made some of my own instead, using decals from a sheet, put on some clear acetate, before painting the reverese in grey, and cutting to fit.
Once dry, I stuck them to the tub, trimming so as they would fit under the coaming, when the halves were put together. I also trimmed and made a little map folder tu go behind therear seat.
Thats it for now, When its all dry, I will neaten things up.
Tim
Hi, Today so far...
I realised that I will prob have to drop the flaps, so a little surgery was required. Thanks to all the great ref photos on this GB,and fellow Britmodeller Tony (started your hawk yet,hmmm?) I think I have come up with something that should look roughly right.
I couldnt work out how to cut the flaps without losing too much of the top part of the wing, so I cut anyway, and replaced the bit I lost, with some thin clear plastic sheet. I simply layed a strip of it on the top of another hawks wing, marked ot what was needed, and cut accordingly, then rescribed in the panel lines. It will need tidying up, but I will do that later.
Tim
this looks fab i have the blue one on my soon to go list
Cheers Mate, talking of which, Can I bag xx178 (I think) I will do them as a brace.
Thanks
Tim
Hi Guys
well, the sunny weather has seriously hampered efforts over the last few days, but I have got a bit done.
I have tarted up the basic kit seat using stretched sprue, modelling tape for belts and paper foil for seat cusions (I tend not to buy AM sets, as I can never fit resin tubs or seats in, and etch baffles me totally.
Basic painting started
A pic of the seats next to a basic kit one. Just need tidying up a bit really.
The only other thing I have done, is add a few wires to the front coaming, and reshape the aft coaming, to make it look a bit more accurate.
Hope all your builds are going well, they all look great.
Thanks, and Happy Easter.
Tim
Cheers dude.
Quick update, I have put the seats in, started to box the wheel wells in and began spraying the blue. I will rub it down with fine cloth once done, before a final coat, if I can find somewhere that wont allow dust to settle on it (yeah right).
Hope your builds are going well.
Tim
wow this will be finished in a day or 2 well done
by the way what paint have you used
Cheers Mark, but that is very optimistic!
I used xtra-colour roundel blue, not my favorite paint as it can take ages to cure, but it sprays ok I guess.
Tim
Evening
I have finished the main painting, so I thought I would start the decaling. I have had to use a mix of a few sets of decal sheets, but I think I will be able to get most of what I need.
Hope your builds are going well :)
Tim
Looking good, how did you do the stripe in the end?
Antony
Hey dude,
decal in the end mate. The one with the herc and harrier on it.
Quick update, I have managed to get the arrow on the bottom, its not quite right but its as close as I think I am going to get it. I will tidy it all up later. I cant make my mind up if to detail the main gear bays or not, its not like you are going to see them, but I know it will enhance the kit. All advice welcome.
CHeers
Tim
Evening,
Todays update, I have managed to get the other stripe and roundels on, and detailed the canopy, to add some handles and wires etc. still need to tidy a few areas up, and sort out the wheel wells. I think I am going to add some engine blanks too.
Cheers guys
Tim
Evening,
I havent had much time recently to do much modelling, but I have managed to attached the flaps, main wheels, and most of the decals. I still need to touch up the arrow, add some little gear doors, stall bars, pitot tubes and all the other bits that I will never find once I have knocked them off.
I have added some rudimentary RBF tags, and restraining sleeves on the gear arms.
Hope you like it
Tim
Im Calling this one done, had some major probs at home, but managed to at least complete this one.
Hope you like it
Tim
